PO48RA
Hi
We have produced a video guide to split ticketing, here is the link;
The video guides you through what split ticketing is, how it works, the main principles and things with which you must comply.
It goes on to recommend 2 sites - This Rail Forums’ split ticket facility and Split My Fare.
It then busts some myths and preconceptions.
I should point out that we are independent and not affiliated to either site - our research and experience has led us to believe that both are comprehensive resources and stand out above similar sites.
We recommend buying from the site where you do the research as it often pays a commission which helps fund future development. Let's be honest; without the research which has led to these tools, rail travel for many would be more expensive.
The video mentions Delay Repay and a 15 minute trigger - it does specify that each operator has its own criteria. Just for clarity; the 15 minute trigger does not apply to all.
Finally, if you feel inclined we’d be delighted if you would subscribe to our channel and like the video.
Thanks
John and Lou
Thanks
John and Lou
