The line from Gillingham (Dorset) to Yeovil Junction is closed for 7 days at the end of Feb and on the weekdays, instead of diverting all day via Westbury as normal, and as advertised on stations, they are instead only diverting occasionally. The rest of the day it's buses only but the buses arrive into Yeovil as the train leaves and so are useless!
Westbound only 6 trains a day divert which are the 0711, 0924, 1124, 1316, 1921 and 2124 from Salisbury. Apart from that, their own journey planner suggests going via Bristol which certainly isn't valid with Network Cards and actually isn't valid with most tickets.
To use the bus you have between Salisbury and Exeter changing at Giliingham and Yeovil you have a choice of:
1352 arr 1642
1447 arr 1849 (66 min wait in Yeovil)
1556 arr 2042 (118 min wait in Yeovil as misses train by 4 mins!)
1647 arr 2042 (68 min wait at Yeovil!)
1801 no connection as misses train at Yeovil by 7 mins
1921 arr 2145 diverted
2124 arr 0005 diverted
So after 1316 direct, you have 1352 via bus then no sensible option until 1921!! Why is this so bad as usually they divert every 2 hours with busses properly connecting in between
1352 arr 1642
