heart-of-wessex
Hello all,
I can't help thinking that an extra set of points at Westbury station that could maybe ease up some delays. Maybe I'm wrong or maybe it's not worth it?
I know it's not the busiest place and paths work out when everythings smack on time. The problem is, not everything is smack on time then everything turns up at once!
I don't always get the 18:09 Cardiff Central service from Westbury, but when I do, it gets held just past Dilton Marsh. I could never understand why until I noticed how the routes are set.
Platform 3 is the one for the 1809 to Cardiff. Platform 2 takes either the delayed Portsmouth or in the case of Friday, the delayed Warminster. The Warminster service came in and the route was set for Warminster. The only thing is it was 'wrong line' running so to speak to the crossover that is closer to Dilton Marsh, then finally the route is clear for the 1809 to Cardiff, which then has to trundle all the way from that signal to the station....well in theory because once the until has cleared the crossover, the route is already set for the delayed Plymouth, which probably has a higher priority because of distance/connections down the line, I get that, but I can't help but think if there was an extra crossover past Platform 2 that got it on the down Salisbury straight away, the Cardiff could come straight in then the route is clear for the Plymouth HST and then everything's fine.
I've also seen an earlier Cardiff been delayed outside Dilton Marsh once, I looked on the live map on the platform to see my train was nearly here, but the service opposite on platform 2 was due to divide, 150 onwards and 153 detached, but the signal from Platform 2 was already set and the train had not split yet, so had to wait for that to split, then depart before the the Cardiff could access Platform 3.
I may be wrong but I thought the idea with any train splitting that the signal would stay red until the detach was successful, and then TRTS when it's ready to go. Unless there is no TRTS of course?
Would this be looked at as a waste of money and not worth worrying about just for some 15 minute delays?
I wonder how many other locations could do with just one extra set of points to solve delay problems?
