What is the point in SPATE boards?
king_walnut
16 Oct 2013
I really don't understand why they need to be there, and I definitely don't understand why some are still there several months later.
Sticking a SPATE notice in the late notice case would be a more than adequate way of letting drivers know that the TSR has been lifted. Just seems like an all round complete waste of time, money and effort.
LowLevel
26 Oct 2013
If the restriction is SPATEd between a driver booking on and reaching it, they'd be obliged to report the fact that it's missing if they just remove the boards entirely.
Presumably subsequently removing the boards entirely is then a low priority job to be done when someone has time or is working in the area anyway.
ComUtoR
13 Dec 2013
Once I've booked on. I may not see any notice cases until I've next booked on. (Which may be a couple of weeks)
But adding an extra notice to read is just as inefficient. At my TOC we do get emails where an ESR or TSR has been withdrawn.
You may or may not be aware that the late notice case is also time limited. It should be used for long term information.
Javelin_55
9 Apr 2020
South East
A good chance it's an outcome of Nuneaton.
If the restriction boards simply aren't there, who's to say the wind hasn't blown them away or have otherwise been removed without authority?
SPATEing stops drivers reporting missing boards and slowing down anyway (delaying the train), in case the above has happened.
Railsigns
15 Feb 2010
What emerged post-Nuneaton in relation to withdrawn TSRs was a practice of leaving the boards in place, but replacing the TSR speed indications with indicators showing the normal line speed. SPATE boards came later.
dk1
2 Oct 2009
East Anglia
If its advertised in the WON then there has to be a SPATE indicator if the work was not done or completed early. It's as per the rules.
Hadrian
28 Jan 2019
Bardon Mill
I assume that I am not alone in needing the acronym SPATE to be translated into english. All explanations welcomed.
skyhigh
14 Sep 2014
Speed Previously Advised Terminated Early - I.e. emergency or temporary speed restriction no longer required.
Boodiggy
8 Nov 2012
You can’t spate an ESR. That can be removed when the reason it it when on for has been correct (like a rail defect) so may only be on for a day. If it is on for a length of time it should become a TSR published in the WON.
Annetts key
13 Feb 2021
West is best
Not entirely true. On an ATP fitted area, any ESR where the ATP has already been adjusted has to stay in place until arrangements have been made for the ATP to be adjusted back to line speed. Until then, it can’t be SPATED or removed.
66701GBRF
3 Jun 2017
Not every driver will see the late notice case. Not every company operates a late notice case.
Dr Hoo
10 Nov 2015
Hope Valley
SPATE was never an acronym, abbreviation or contraction. It was a 'Code Word' from the old standard telegraphic code book.
Strictly it meant "Trains between the following points may run at ordinary speed on and after the date named. Withdraw restriction and reply".
As with many Code Words (such as CAPE for cancelled) it has found its way into railway jargon and people have made up their own 'definitions' or origins.
Mcr Warrior
8 Jan 2009
What was the original telegraphic codeword meaning of 'SPATE', before the railway 'backronym' came into being?
Dr Hoo
10 Nov 2015
Hope Valley
As already quoted from the Code Book:
Hadrian
28 Jan 2019
Bardon Mill
Thank you for the explanation.
I had forgotten SPATE, and many other Telegraphic Code words, in the 49 years since I last regularly used them.
