What is the shortest minimum connection time (MCT) in the whole of the National Rail network?
miklcct
2 May 2021
Cricklewood
Is there a station with minimum connection time (MCT) being 1 minute? If not, what's the minimum MCT within the whole network, and are there any connections which actually take advantage of such MCT to have a seamless connection?
Moreover, is it physically to have a timed connection to have a 0-minutes MCT by running two trains into an island platform simultaneously, exchange passengers and depart immediately?
Ianno87
3 May 2015
Thorpe-le-Soken has a minimum connection time of 1 minute, because all interchanges are cross-platform (between Clacton/Walton trains)
Mcr Warrior
8 Jan 2009
Are there any locations (on Southern) with minimum connection times of less than 3 minutes?
miklcct
2 May 2021
Cricklewood
Thank you - do you have experience changing trains at the station? In case if one train is delayed, will the other train wait for the delayed train to come in order to exchange passengers?
Mcr Warrior
8 Jan 2009
Believe that trains from off the Clacton branch (which normally then run semi-fast towards Colchester and beyond) are normally always timetabled to "overtake" trains from off the Walton branch (which normally call at all stations) after they pass each other at Thorpe le Soken. No doubt there could be exceptions.
LRV3004
17 Mar 2015
Minimum Connection Time.
I remember in the old National Timetables, where all the stations were listed on the pink pages, a black square with a white number in next to a station name denoted the minimum connection time for a train to be classed as a connection. For example, say Preston had a “10” in the box next to it on the pink pages, if your connecting train was due out 9 minutes after you arrived off another train, it wasn’t technically a connection even though you could probably make it easily.
There was a footnote saying that if no number appeared next to a station name, then the minimum connection time was 5 minutes.
306024
23 Jan 2013
East Anglia
Yes made the connection at Thorpe quite a few times over the years. Not surprisingly it depends on the size of the delay. Towards London the trains have only come a few miles so are rarely late anyway. From London the Walton train won't wait if it delays its return working, although GA have become less flexible with their connection policy in recent years.
A 0 minute connection would be half a minute in practice if anyone attempted that, but would require Red Arrows precision and only passengers named Usain Bolt would be allowed to travel.
Class 170101
1 Mar 2014
Or stick their foot in the door.
_toommm_
8 Jul 2017
You can always check BRTimes now for station connection times, including fixed links e.g. the time given to connect from Manchester Victoria to Manchester Piccadilly.
etr221
10 Mar 2018
I remember on the London Underground, there were a number of stations where cross platform interchanges were made, and there were signs reminding guards of this, and that they should wait if necessary to make the connection.
ABB125
23 Jul 2016
University of Birmingham
That's very interesting, I didn't know that! Thanks :)
alistairlees
29 Dec 2016
Sutton has a minimum connection time of 1 minute for Thameslink to Thameslink. It’s because they are actually the same train going round the Sutton loop.
LRV3004
17 Mar 2015
Oh yes, the advancement of technology has come on in leaps and bounds since the days of the National Timetable “bible”!
High Wycombe is probably the most unusual example of a short MCT. It's just 1 minute.
That's clearly intended to allow an official connection from a High Wycombe terminator to an Oxford/Aylesbury/Birmingham service despite the 2 minute public differential ("fiddle" time) that's applied to the arrival time of the terminator.
However, due to the skipstopping nature of the Chiltern timetable, there are journeys where you will be advised to make a 1 minute connection from a northbound service to a southbound one and vice versa. For anyone that's not familiar with the layout, the station is in a cutting and the two platforms are offset from each other:
The stopping points are right at the extreme end of the platforms, and doors close up to 30 seconds before departure. So you have essentially no chance of making a one minute connection, even if you know what you're doing and the trains are on time, if you are unlucky enough to be changing from one short train to another.
You would have to manage a 200m sprint up and down a footbridge and along two platforms in less than 30 seconds.
Cherry_Picker
18 Apr 2011
What journeys would you be making a northbound to southbound connection on at High Wycombe? I’m sure there are some tiny edge cases, but the northbound Wycombe terminator to the northbound Oxford/Birmingham express is such a useful connection I figure you need that facility.
One example would be Beaconsfield to London - if you've just missed a direct train, in quite a few hours the fastest connection then involves going via High Wycombe.
For example, this afternoon there's a non-overtaken itinerary departing Beaconsfield at 16:07, changing at High Wycombe with a 2 minute connection. That's between a northbound Oxford and a southbound Birmingham service, so there isn't any 'slack' there.
Ianno87
3 May 2015
Examples like that make me wonder why interchange times aren't/can't be specified based on booked platforms.
That would make an awful lot of sense, but exactly the same as changing the meaning of the 'reservations' status of a train schedule, it would require cross industry cooperation and funding to change booking engines. So unless there's a way that it can be handled in a 'failsafe' way I don't think it will happen.
Hopefully PPM will soon be extinct across the industry, then the public differential at the destination can be eliminated, and a 1 minute connection time will no lnoger be required to show a valid connection from one train to the one behind it!
Cherry_Picker
18 Apr 2011
That’s such an edge case though. If you’re looking at going to London via High Wycombe on the 16:07 northbound departure then it assumes you’ve just missed the 16:06 non stop direct service but are too busy to wait on the 16:28 stopper that comes from High Wycombe anyway? It’s highlighting an anomaly but it serves a practically non existent scenario.
The northbound connection is just so useful. Unless something is wrong the people looking to make it will always make it because of the layout of the station.
D6975
26 Nov 2009
Bristol
Am I imagining it or did Clapham Jn used to have 2 different connection times depending on whether you were changing between the two halves of the station or not?
alistairlees
29 Dec 2016
There's no provision in the data for different "halves" of a station to be identified and to have different MCTs - they would have to be separate stations with separate CRS codes.
There probably was (or is?) a different MCT depending on the TOCs you were interchanging between, which is supported in the data. This is called "TOC-specific interchange".
Ianno87
3 May 2015
Yes, Clapham Junction is done by TOC code, as every platform is only generally used by one TOC (apart from the occasional Overground trains into Platform 17)
SargeNpton
19 Nov 2018
In journey planners, and in the Timetable Planning Rules, the default minimum connection time at Clapham Junction is 10 minutes. For connections between two Southern services that is reduced to 5 minutes. If any system is using values other than those then it's doing so of its own initiative.
D6975
26 Nov 2009
Bristol
Thanks for that peeps. I though I'd seen reduced changing times somewhere, must have been when looking up a Southern only journey.
