It is exactly that, just west of the Farringdon platforms, the structure the underground tracks are on is known as the ‘Ray Street Gridiron’. Nowadays you’d see Thameslink 700s at the low level, and LU s stock above.It looks suspiciously similar to farringdon
Also, what approximate year does the image (posted by the OP) likely date to? Before or after WW2?
Cricklewood first had BR Type 2s in 1960 and Finsbury Park in 1961.A Sulzer Type 2 (class 24) in original green livery with no yellow warning panels would put it in the 1958 to 1965 ish era I would guess?
It is a cross London transfer freight, if from the GN starting at Ferme Park. The destination is likely to be Norwood Junction or Hither Green.I wonder what is the Type 2 hauling and where it might it be going. From what can be seen, the first vehicle looks in profile more like a 4 wheeled van than coaching stock, or is this just a trick of the light?
The Southern Region didn't use standard disc codes, it isn't a disc set up that I recognise.Were special headcodes used on the Widened Lines?
The 1960 SR(SE) Sectional Appendix gives the code as "ER to/from Lower Sydenham." Lower Sydenham was (principally) traffic for the Gasworks, so what the van behind the loco is doing I don't know - I don't think it's a goods brake.I wonder what is the Type 2 hauling and where it might it be going. From what can be seen, the first vehicle looks in profile more like a 4 wheeled van than coaching stock, or is this just a trick of the light? Does the headcode give any clues? Were special headcodes used on the Widened Lines?
BR 24 Bo-Bo No D5065 with a Brent to Norwood Yard transfer freight passes Crystal Palace (low level) on 23 August 1962.
Would a train to or from Brent/LMR have a different disc code?The 1960 SR(SE) Sectional Appendix gives the code as "ER to/from Lower Sydenham.
I suppose the freight might have called at Blackfriars Goods en route?
I wonder how precise these headcodes for cross London freights were - or needed to be. Presumably the original idea was for the headcode to help staff, especially signallers, identify the routes of specific trains. Particularly useful at junctions etc. Others will know more, but by the 1960s wouldn't most of the lines involved have been signalled from boxes equipped with illuminated track diagrams, making the need to physically observe trains from most boxes a dying practice?Would a train to or from Brent/LMR have a different disc code?
On the GN traditional manual signalling was alive and well until the 1970s resignalling prior to suburban electrification. I think that the southern end of the Midland Main Line was the same.Others will know more, but by the 1960s wouldn't most of the lines involved have been signalled from boxes equipped with illuminated track diagrams, making the need to physically observe trains from most boxes a dying practice?
Good point. Too much of my youth spent south of the Thames where much had been resignalled in the 1950s!On the GN traditional manual signalling was alive and well until the 1970s resignalling prior to suburban electrification. I think that the southern end of the Midland Main Line was the same.
and was a contributory factor in the St Johns (Lewisham) collision in 1957, when a signalman tried to direct a Hastings train down the Hayes branch (both being simply described as "electric" - although the Hastings was in fact a new-fangled diesel, for which no code yet existed). By the time the confusion had been sorted out, a queue had built up in the fog, into the rear of which ran a steam-hauled Kent coast express.Even if it was track circuited, in those days the track-circuits only indicated where the train was, not its destination or reporting number: I think that a lot of the routing indicators south of Snow Hill were of the revolving indicator type, which had only a limited number of indications and could not show everything. Displaying the correct headcode is important for when you start, to get the routing codes started correctly, and through the journey as a check. Otherwise you get a goods stopped across the junction with the driver contacting the box and saying, “Excuse me, Mr Signalman, but this train is destined for Hither Green, not the Central Division”…or something like that. Headcodes do matter: I have seen the fun that can ensue if the numbers get confused or swapped.
Oh yes, a very polite version of some conversations had via the SPT lines....“Excuse me, Mr Signalman, but this train is destined for Hither Green, not the Central Division”…or something like that.
The only time I know of that the name 'Spitfire' is not remembered with fondness/reverence...etc..perhaps?and was a contributory factor in the St Johns (Lewisham) collision in 1957,
Indeed - West Hampstead PSU took over completely on 2nd December 1979. But I think every manual box had some track circuits. At St Albans South we got our first TCs in December 1915, although they used electro-mechanical repeaters rather than lamps for some years. We think the 1915 TCs were part of the 2000+ locations the MR decided needed TCs following the 1910 Ais Gill accident.On the GN traditional manual signalling was alive and well until the 1970s resignalling prior to suburban electrification. I think that the southern end of the Midland Main Line was the same.
