The thread on "worst" tube lines mentions that the Southern (newer) Jubilee and Battersea Northern parts are extremely noisy. Is there some reason (safety-related, environmental) why that's the case? It's not good for the passengers, after all...
Not absolutely sure, but I would have thought the bigger tunnels are a factor, as well as higher speedsThe thread on "worst" tube lines mentions that the Southern (newer) Jubilee and Battersea Northern parts are extremely noisy. Is there some reason (safety-related, environmental) why that's the case? It's not good for the passengers, after all...
Also concrete panel linings instead of iron rings.Not absolutely sure, but I would have thought the bigger tunnels are a factor, as well as higher speeds
Isn't that because there was next to no long welded rail anywhere until the mid-1990s?I suspect the bigger issue is the extensive use of rail grinding these days, which tends to leave behind the annoying high-pitch sound. This is an activity which I'm not even sure LU carried out in the 90s, but nowadays it is done very regularly. It essentially prolongs the life of rail, and is very significantly cheaper overall than re-railing.
Was flicking, and see Vossloh have just released their results, with picture of a high speed grinding machine. Just out of interest do we use these in UK?Rail grinding doesn't make the track louder. It does change the sound of it for a few weeks but it soon goes back to sounding normal. And they definitely are not out grinding every few weeks, more like once a year.
The Jubilee is so loud that I use the district and DLR to get from Westminster to canary wharf if I'm not in a rushThe thread on "worst" tube lines mentions that the Southern (newer) Jubilee and Battersea Northern parts are extremely noisy. Is there some reason (safety-related, environmental) why that's the case? It's not good for the passengers, after all...
Vossloh record results in 2022
The order book of Vossloh, which specializes in the supply of track components and track machines, reached a record value of 1.25 billion euros in 2022 (+31.6%www.railway.supply
The Eastbound running Tunnel on the Central Line between Stratford & Leyton is back to being very noisy again, despite recently it turning into a weird howl that wasnt as painful on the ears that is still evident on the Westbound Tunnel at the Stratford end so whatever was done during the engineering works seems to have already failed given how noisy it already has become in less than a month.The Central is also awful for noise between Liverpool Street and Stratford.
My son hates loud noises and covers his ears on this stretch, on Saturday it was that bad I almost joined him in covering my ears too.
I thought there was some kind of randomised fuzzing for exactly this reason, so that the trains don't e.g. begin braking in exactly the same spot?You might also add ATO to the mix, as the nature of every train being driven in exactly the same way seems to wear the track in particular ways.
The engineering works in April/May was for track renewal between Leyton and Leyton tunnel mouth and the engineering works in March was for rail grinding between Queensway and Leyton.The Eastbound running Tunnel on the Central Line between Stratford & Leyton is back to being very noisy again, despite recently it turning into a weird howl that wasnt as painful on the ears that is still evident on the Westbound Tunnel at the Stratford end so whatever was done during the engineering works seems to have already failed given how noisy it already has become in less than a month.
Not strictly on topic but it was mentioned up thread about there being a 50 mph speed limit on the Battersea section at the moment, why is this?
