Because doing double deck in the UK loading gauge produced something incredibly grim and cramped. It also didn't add much capacity - it was maybe 1.5x?
The 4DD has a chequered history (and yes the photo is genuine). It wasn't really double-deck but as you can see from the photo a staggered arrangement. You'd have the upper passenger's feet between lower compartment's head height.
It didn't go anywhere because it was cramped, expensive to maintain and had low dwell times compared to a single deck train.is a contemporary Pathe newsreel, and despite the optimistic tone, you can see the problems.
Double-decker trains might fill a small niche as we see across Europe, but for the UK it was never going to work.
AIUI All HS2 platforms will be built for UK-Sized trains so although they have the additional vertical clearances the trains won't be any wider in the lower part of the profile. Standard UIC Gauge trains thus won't fit even captive to HS2.HS1 and HS2 could take double-deck designs as used on SNCF's LGVs, for stock that is captive to HS routes in the UK.
But for various reasons the procurers have gone with lighter single-deck designs.
In HS2's case it is because the trains need to run through on to classic NR infrastructure.
Wow this sounds like a Heath Robinson concept. Thanks for the history. The image just appeared on a social media feed with no additional information.
I can see why these did not take off!
Touché.Surely they don’t fit a small niche, hence why UK has never successfully introduced them![]()
also thats 1.5x of compartment seatingBecause a proper bilevel unit wouldn't fit within the UK's restrictive loading gauge, and the 1.5x increase in capacity is somewhat mitigated by the increased dwell times at stations which is especially unhelpful on some of the busiest routes in the country with high frequency as well as the reduced acceleration due to the increased weight of the train itself, both of which would require bigger gaps in the timetable. Double-decker trains might fill a small niche as we see across Europe, but for the UK it was never going to work. That's basically the whole answer to your question.
Standing room yes; seating no. Non-corridor SUburban stock had a far higher seating capacity than open stock ever could.also thats 1.5x of compartment seating
can prob get that 1.5x from open plan not to mention standing room
One might argue that they're causal: if you've inherited a small railway loading gauge then there's a greater motivation to build your new motorways with larger clearance, and maybe even some futureproofing. If you've got a generous loading gauge already, then there's less ugency to over-engineer your roads.It's curious how the UK is the reverse of mainland Europe with regard to road and rail - our standard road bridge height is higher than most of Europe uses (hence very high lorries and double decker buses) but our rail loading gauge is much smaller.
British Rail Research looked into double deck trains within the UK loading gauge, 70s or 80s I think - before my time there but someone who later became my manager was involved with it. I believe it was longitudinal seating down near track level, which would have been very cramped because of the narrowing of the gauge below platform height, and more normal transverse seats on the upper deck but with quite limited headroom.Fundamentally the problem the UK has with double deckers is that our loading gauge gets quite narrow below solebar level. Most European and US double deckers gain the space by having the train quite wide well below our platform height. We also have less height to play with in general (even a normal double decker bus wouldn't fit).
Not to mention the fact that whereas we pioneered railway engineering, we were pretty late to the motorway party.One might argue that they're causal: if you've inherited a small railway loading gauge then there's a greater motivation to build your new motorways with larger clearance, and maybe even some futureproofing. If you've got a generous loading gauge already, then there's less ugency to over-engineer your roads.
To underline this point, see this image:British Rail Research looked into double deck trains within the UK loading gauge, 70s or 80s I think - before my time there but someone who later became my manager was involved with it. I believe it was longitudinal seating down near track level, which would have been very cramped because of the narrowing of the gauge below platform height, and more normal transverse seats on the upper deck but with quite limited headroom.
The lime green profile is W6, which is a good approximation of the standard carriage profile. you can see that it is noticeably narrower below the platform, because of how close to the rail it is. You can also see the problem with the headroom quite clearly.Image of UIC loading gauge profiles compared to a typical British platform and Loading Gauge
Bulleid.
Noted for innovation, but rarely for practicality!
This first document is the most relevant to this thread, as it is a reasonably thorough feasibility study. Its main conclusion is:The Department commissioned in 2007 a study by Network Rail into the use of double-decked trains which can be found at Preliminary Evaluation of Double Deck & Extra Long Train Operations. The outcome of the report found that it would not be economic to introduce double decker trains on the existing rail network.
In 2010 the Department commissioned a study by Atkins into alternatives to the building of HS2 which considered the use of double decked trains on West Coast and Midland main lines which can be found at High Speed 2 Strategic Alternatives Study Rail Interventions Report, the conclusion in respect of double decker trains rejected the idea because it was significantly more expensive and disruptive.
Network Rail have also undertaken a study to look at the potential use of double-decked trains on the Wessex Route for services into Waterloo. Details can be found at http://www.networkrail.co.uk/long-term-planning-process/Wessex-route-study/.
The conclusion of this analysis, combined with the overall structure of the analysis vehicles, effectively confirmed that a vehicle fitting within the existing overall static height of 3990mm would not provide acceptable headroom. This conclusion also addresses the objective to improve the passenger experience and provide for a population that is taller than it has been historically and forecast to have an increasing body mass index.
The adoption of an existing European profile train is considered uneconomic because of the extensive infrastructure work required to accommodate the longer bogie centres with the resulting implications for end throw and mid throw. Work would also be required to the platforms to suit their highly efficient end vestibule arrangements and hence release width for the lower deck. These alterations would be further complicated by the need to continue to support the use of the existing rolling stock. One feature, seen in some European stock, that would be beneficial is the through connection at the high level, but was not assessed in this report.
I find it odd that they are so positive.Network Rail is continuing to undertake development work to understand the scale of network investment required to operate double-deck trains on the SWML to Basingstoke. Initial conclusions, however, indicate that this is likely to be a poor value-for-money solution.
Yes. Would be good to see them restored so you could go inside and experience the design!If anyone is interested, 2 of the coaches have been preserved by the Bulleid 4DD group and are currently stored at Sellinge in Kent.
More information at: https://www.bulleid4dd.org.uk/
Paul Maynard MP (then junior transport minister for rail) answered a written commons question about this subject (increasing capacity in general and and using DD trains in particular) on 22 November 2016:
The second does not consider DD trains, it just reports that previous studies rejected the ideas as impractical. The third link no longer works, but it must be the 2015 Wessex Route Study. I have a draft copy of that, and this is the final version (substantially rewritten).
The Wessex route option proposed was for double deck trains too big for the existing gauge to run Basingstoke-Waterloo only, with infrastructure work to allow them to fit. An interesting idea, of which NR concluded:
I seem to recall there is one of these at the East Anglia Transport Museum in Lowestoft, which you can go inside. It is cramped indeed!Yes. Would be good to see them restored so you could go inside and experience the design!
Presumably all other trains on this section would have to run non-stop because platforms would need to be set back to clear the wider trains, resulting in a dangerous platform gap for narrower ones.The Wessex route option proposed was for double deck trains too big for the existing gauge to run Basingstoke-Waterloo only, with infrastructure work to allow them to fit. An interesting idea, of which NR concluded:
Or they'd be confined to the Slow lines, with standard platforms on the fast lines.Presumably all other trains on this section would have to run non-stop because platforms would need to be set back to clear the wider trains, resulting in a dangerous platform gap for narrower ones.
