As you can see from the HS2 routemap, it is as if HS2 is being built to allow journeys to be made to/from the northern cities involving London but not between them. For example, if one wanted to travel from Manchester to Glasgow (a route to Glasgow and Edinburgh being planned in the long term) with the network built as proposed, they would either have to get a London-bound train and change at Birmingham International, or take the old Transpenine Northwest if they wanted to travel directly. Why hasn't anyone seen through this?
Instead, and to put it bluntly, if it had been planned by a normal person, there would be a single line leading up to Scotland that would pass though either Liverpool or Manchester (your pick) which would fork into Edinburgh and Glasgow branches. Whichever city out of Liverpool and Manchester isn't passed through would get a dedicated branch line. Say it's Manchester that the line passes through, surely it would be cheaper to built two twin tunnels under the city north-south and at Piccadilly build a two platform underground station, than have the line only go up to Piccadilly but built a mighty terminus there? And while we're at it, why not have a single station at Birmingham, not two and again tunnel HS2 under the city and have a two platform (maybe four, should Shengen rules require segregation) station there?
This way we save on duplication, we save on Termini and surely allowing people from Manchester to travel to Glasgow when they are on the same axis is the obvious thing to do? And when it comes to Birmingham, surely its best to have one station, not two, and a city centre one would be good at that?
