ÖBB orders double decker railjet
Mike395
23 May 2009
Bedford
Does it mean that more traditional intercity stock will be retired or it’s just to boost the railjet fleet and free-up traditional railjet sets for international services???
The latter I believe - not aware of any plans to retire the current fleet.
dutchflyer
17 Oct 2013
Read somewhere-likely some german forum, that OeBB expects at least double demand i the upcoming 10-12 yrs-also due to the cheap General ABO (though not even as cheap as the one in DE=-Germany, but thats not for IC). So they need more stock.
That oldest stock will get to the scrapyard and new stock comes in is natural and an ongoing process, with some ups and downs in the economic cycle.
They are not all intercity stock
14 are 6car for long distance services (about 480 seats in 1st & 2nd class), 21 sets are 4car for local services (about 380 seats)
This takes it to 76 sets out of framework agreement for upto 186 sets
The Austrians are doing similar to Italy and France, huge framework agreements and calling off mechanically identical orders fitted out as required, unlike UK Operators who seem to each prefer a unique design which often doesn't then work properly, and being in tiny batches often costs more.
Stephen Lee
7 Jul 2019
I assume the traditional Eurofima stock will be sold with the gen2 RJ stock?
Maybe
I remembered that ÖBB still has a framework of up to 700 coaches ranging from nightjet to railjet. ÖBB ordered 33 7-car night trains(231 coaches) and 8 9-car day trains(72 coaches), and ÖBB can order 397 more coaches
StephenHunter
22 Jul 2017
The Eurofima stuff probably - and I can see that being snapped up by open access operators, because their sliding doors make them more PRM-TSI compliant than Corail or UIC-X/Y/Z types.
Austriantrain
13 Aug 2018
I hope not. ÖBB are desperately short on long-distance rolling stock and will need more once the Semmering and Koralm lines are open. Trains are often full to bursting and Long-distance stock is routinely replaced by commuter trains on some services.
For the moment, once the new RJ2 sets are in service on the Brenner, the RIC cars will replace German IC trains on the Munich - Graz line and probably will be used to strengthen services elsewhere and/or run extra trains.
The new Double-deck Stadler KISS trains will replace RJ1 sets on the slow Wien - Salzburg service, which is really an Interregio used by lots of commuters. The RJ1 sets will then move to the Südbahn and there is talk of another small order of RJ2, also for Südbahn (where double-deck stock cannot run until the Semmering tunnel opens, hopefully in 2030).
Stephen Lee
7 Jul 2019
What about Munich-Klagenfurt?
Austriantrain
13 Aug 2018
As I stated above, ÖBB will be probably order another 12 RJ2 sets für Südbahn services, but that has not been confirmed yet. It was originally to be 20, but it was decided to invest in long-distance KISS instead. I highly doubt more RJ2 sets will be ordered- the days of ordering Siemens Viaggio for ÖBB day services are probably over; I suspect the next generation will be EMUs. As to NJ, it might depend on the success of the sets currently on order, but I wouldn’t hold my breath on more than the current 33 sets.
Gen2 RJ stock?
The new railjet sets currently in delivery.
DanNCL
17 Jul 2017
County Durham
Are the EC services to be split at München Hbf when this change happens or will the ÖBB locos and stock be running through to places such as Saarbrücken?
Austriantrain
13 Aug 2018
They need to reverse there, which an EMU makes easier. As does a Railjet rake.
They will probably be top-and-tailed. There is just no alternative available. DB IC1 sets are literally falling apart and there is no new stock available yet.
Austriantrain
13 Aug 2018
Believe RJ1 is a Taurus-hauled set with a driving trailer of that style and RJ2 is Vectron-based.
No, nothing to do with traction itself. However you are right insofar as the RJ2 does have Vectron-styled fronts (because the original front wouldn’t conform to current crashwortiness standards).
Apart from that, it is simply the latest iteration of the Siemens Viaggio - in the RJ2 case with low-floor coaches. And 9 cars, but this is just ÖBBs individual decision; Siemens would happily build 7- or 10-car sets.
In Siemens speech, they are called DANI sets (day-night, because the new NJ are basically the same). The name RJ2 is purely unofficial.
andersj
29 Jan 2021
Denmark
Railjet 1 are Siemens Viaggio Comfort coaches while Railjet 2 are Siemens Viaggio Next Level coaches with partial low floor.
ÖBB is the first and only customer for the Next Level coaches, which where ordered in 2018.
Stephen Lee
7 Jul 2019
ICE4 on those trains that currently use DB IC sets.
Why don’t they use ICE-4 to run on the Graz route
Correct, ÖBB is short on both day and night long distance rolling stocks. However, I wondered if there are any nightjet/international service expansion plans to be implemented
Austriantrain
13 Aug 2018
When will the new nightjet sets be finally put into service……
Towards the end of the year, is the official line, but nobody seems to be sure.
Several stations with low platforms, including one that still has earth platforms. Also, these services will disappear from 2026.
Stephen Lee
7 Jul 2019
why the service are going to disappear?
Austriantrain
13 Aug 2018
With the opening of the Koralmbahn in December 2025, international long-distance traffic will switch to a Salzburg- Villach - Graz (-Vienna) route. The Ennstal line, through which the trains currently run, will get an Interregio service with EMUs.
