0521 London Northwestern Crewe - London Euston
dangie
4 May 2011
Rugeley Staffordshire
Out of interest, could anyone tell me why the London Northwestern Railway 0521 Crewe - London Euston does not:
  1. Go via Stoke-on-Trent
  2. Why it passes through Stafford without stopping
Its first stop is Rugeley Trent Valley.
Ianno87
3 May 2015
So it can run via Stoke when the Stafford route is blocked for overnight engineering and vice-versa. Unit comes from Crewe. When first introduced it ran ECS and started in service at Rugeley.
bionic
8 Nov 2013
It's usually booked via Hixon, presumably for route retention purposes.
Merseysider
Fares Advisor
22 Jan 2014
Interestingly it doesn’t call at MKC either, presumably because there’s a Virgin from Manchester hot on its heels
Ianno87
3 May 2015
It is one of the Northampton peak flyer services introduced in (IIRC) December 2013. Prior to this it used to go forward from Northampton was what is now the 0732 Northampton-Euston semi-fast (with a longer stand at Rugby, where it terminated as one service and re-started as another under ye olde Moderation of Competition protection for VTWC).
Then in Dec 13 the 0716 Northampton-Euston non-stop was introduced, and the ex-Crewe stepped up to form it as one through service.
Merseysider
Fares Advisor
22 Jan 2014
That’s interesting - thanks :)
pt_mad
26 Sep 2011
Also note its an 8 car which prevents it from stopping at the local stations around Stoke.
Interestingly this service was mentioned in the office of rail and road application being discussed in the main West Mids franchise thread. From December it looks like the application is for this train to run later than at present, and planned to go mainline via Weedon between Rugby and Milton Keynes. With a different service calling at Northampton instead.
Deafdoggie
29 Sep 2016
It doesn't stop at Stoke, as Stoke not open then, and it is a Virgin station not LNWR. I guess it could call at Stafford, but I can't see it would pick many-any-up
I also don't know how it is crewed, as I thought Crewe LNWR Drivers and Guards didn't go further south than MKC, so not sure where this changes over?
DarloRich
Fenny Stratford
Northampton?
sufian123
1 May 2017
At the MTM event I asked where the crews change on Euston to Crewe they said sometimes one crewe can go all the way to Crewe or change at Rugby or Northampton.
sd0733
7 Nov 2012
At Crewe we work 1u00 to Northampton then work 2u21 06:24 eus to Crewe back.
Drivers sign as far as Northampton whilst guards sign to Milton Keynes via weedon and Northampton.
Crewe conductors work all trains on the Trent to/from Crewe as far as Milton Keynes or Rugby with the exception of 05:45 Northampton-crewe and 7:55 back to Euston, 13:46 euston to Crewe and 17:02 return, 16:46 Euston to Crewe and 20:10 back to Northampton.
sufian123
1 May 2017
Thanks
Mugby
25 Nov 2012
Derby
If I may add to this thread, I was at Stoke-on-Trent this evening and the 1902 Crewe to Euston WMT service was reported as cancelled.
It did apparently run though, departing Crewe almost half an hour late but only 5 minutes down at Stafford. Obviously it went direct to Norton Bridge.
This is the last Up WMT service on Saturdays and passengers for Stone were put in taxis. Does anyone know how other passengers, Rugeley, Tamworth etc. would be catered for - and what caused the initial delay?
