1950s Steam Engines
BobDaviesrbd
2 Apr 2022
Holbury Southampton
In the early 1950s I watched the trains at St Albans City LMS Station. Would I be correct that there would have been a Black Taper engine? If so could it’s number have been 6782? If not, would this have been the number of another engine, perhaps a shunter?
Cowley
15 Apr 2016
Devon
Welcome to the forum Bob.
By taper do you mean a tapered boiler?
Harvester
9 Nov 2020
Notts
I don’t think that number (6782) existed in BR steam stock, either in WR numbering or with a (3), (4), (5), (6), (7), (8), (9) prefix.
Magdalia
1 Jan 2022
The Fens
This is all before my time! but I suspect we are talking about Jubilees, Black Fives, or possibly a memory that conflates both classes. The date is unclear too, St Albans City was LMS to the end of 1947, then British Railways following Nationalisation. This is important regarding loco numbers: LMS numbers were 4 figures, BR added a 4 onto the front of the LMS numbers.
One reason I suspect that the memory conflates both classes is that Jubilees had tapered boilers, but they were red. Black Fives on the other hand were.... black!
There's lots on the internet about both classes, which could bring this memory into sharp focus.
Lucan
21 Feb 2018
Wales
What made you remember that particular number? There must have been lots of different locos passing throough and around St Albans then.
If there had been a 6782 in 1958 it would have been a 0-6-0 Western Region pannier tank (which for the OP's info would look nothing like a tapered boiler loco). But the 67xx numbers did not go above 6778. Wondering if it was a 5 digit number starting that way, it would have been a Midland Region (ex-LNER) Class L1 2-6-4 tank (which would have been more likely at St Albans), but their numbers stopped at 67800 and they did not have tapered boilers.
70014IronDuke
13 Jun 2015
It could have been an odd loco working, perhaps from Neasden, but L1s never worked on the Midland in normal traffic.
There were plenty of Black 5s, of course, it could have been 44782 or some other similar combination. Royal Scots first made their way to the Midland on a regular basis in 1958, but they would have had a number 461xx up to 46169 (46170, the final engine, was banned on the Midland, IIRC). Perhaps the OP might look up Royal Scot class in Wikipedia and see if they matched his memory. They all had distinctive, curved smoke deflectors. 46112, which was allocated to Nottingham for a while, was certainly a regular engine through St Albans c 1960-61, perhaps earlier.
grumpyxch
22 Apr 2015
BobDaviesrbd (the original poster for this subject) stated "early 1950s". After nationalisation it took a long time to give some locos their BR numbers. Perhaps he remembers a loco that was still bearing its pre-nationalisation number. Perhaps the loco was old enough even then to not have much life left so it was never given its BR number. Mind you, that doesn't mean he has remembered the number 100% accurately. After all, it was 70 years ago - I have problems remembering locos I saw in the mid 60s
Gloster
4 Sep 2020
Up the creek
My understanding from the original post is that the number is just recalled from memory. If not it might help if the OP said where it came from.
30907
Indeed, he has quoted a 4-digit number.
It did happen, but not to express engines with taper boilers AFAIK!
Clarence Yard
18 Dec 2014
St Albans had both 1F tank 41672 and 3F tender engine 43782 in the early 1950’s, which is where the number memory might come from.
11 Mar 2022
I know what you mean, although the 5700 class did have tapered boilers
