222016 - New nose cone?
asylumxl
12 Feb 2009
Hiding in your shadow
Saw a 222 in the Cricklewood sidings today (assuming it's 222016) with an entirely yellow front nose cone.
Looks quite good. Is it 222016? I also wonder if it will be put into service as is.
20 Jan 2009
I saw it at West Hampstead (Thameslink) last Friday too, must have been out for a while (?)
mallard
12 Apr 2009
I suppose this was rushed into service to cover for 222005 then?
MCR247
7 Nov 2008
Surely 222005 could run without the affected coach?
12 Feb 2010
Taunton
If only it were that simple. Thanks to so called modern electronics, it means that the on-board computers would need to be reconfigured/reprogrammed to compensate for the lack of the damaged vehicle.
Then you'll need to alter the inter-vehicle jumpers as well; Never used to have these problems with good old fashioned LHRS! :roll:
MCR247
7 Nov 2008
Why? 222104 took on 016s Coach B :?
Ibex
23 Jan 2010
Excuse my ignorance but was this the unit that was involved in the fatality at Elstree & Borehamwood not long ago?
12 Feb 2010
Taunton
Indeed. And furthermore, the entire fleet was reconfigured to new lengths, so the idea that it wouldn't work goes out the window.
You still have to re-program the computers so they know what coach is where, also the vehicle number into it to; Then there's the jumpers to do, then you need to alter the maintenance cycles as well, because the replacement coach will have increased mileage accumulation.
jopsuk
13 May 2008
Better too much yellow than not in service. I guess they'll paint the other colours on when they get a chance,
That's what asylumxl alludes to, yes.
222001
1 Sep 2006
Chesterfield
Seems easy enough though. EMT put coach B from 222016 in 222104 for a couple of weeks without issue. At one point 222002 was mixed with 222008 too.
Pumbaa
19 Feb 2008
Vaguely related - a 221 is now to receive a new nose cone;
Click
Does mean that Virgins stock woes continue; they've just shoved 390004 back out into service as an 8-car (minus coach E) which is being repaired after collision damage at Oxley, and is stuck on an EBW diagram all day avoiding peak flows where possible, and they lock away WB64 only to lose another unit! D'oh!
WillPS
18 Nov 2008
I was thinking then - oooo an XC unit without a stupid triangle on the front, but no, it would be a Virgin one wouldnt it :)
I like 222016. From a certain angle it looks like a LOROL unit.
Death
23 Oct 2006
Sat at the control desk of 370666...
Reminds me more of a class 370...
So I'm not the only one who thought that, then? <D
Although that said; Photoshop the colours a little bit and it'd bear an even more striking resemblance to the APT-E, I reckon! :)
The collision between body and train at Elstree & Borehamwood a while back damaged the original nose cone.
Vaguely related - a 221 is now to receive a new nose cone; Click
Oooof...Doesn't sound like it's a good time to be working in a railway "body shop" unless ye have the stomach for such things - My sympathies go to the drivers and others involved in the mess.
On that note though - With apologies to anyone who considers it in bad taste (Which is not as it's intended) - I've always wondered just how far I could catapult a Chav's corpse with the nose-cone of an HST carefully applied at about 500mph or so... :shock:<D
