92044 from Brush Traction
10 Jan 2020
York
Hey there, 92044 Couperin seems to be on it's way to Crewe right now, does anyone here know what traffic it will be put on?
It doesnt have the CAF/Dellner mods so obviously not beds,
but does anyone know which freight services it will be deployed on?
Many thanks.
DBS92042
13 Apr 2019
Many thanks.
My guess is that it'll probably head to Dollands Moor to work the Channel Tunnel/HS1 freight for GBRF or DB (a bit like 92032 does at the moment)
10 Jan 2020
York
cheers :)
But surely not ? As far as I understand, GBRf do not operate any regular chunnel flows other than the China Clay, which is hardly a common service. 92032 is (or was) on loan to Db, but i can't imagine GBRf overhauling a locomotive just to serve Db, thats just not feasible. So if Couperin is to go into chunnel flows, does this suggest GBRf acquiring a new chunnel flow?
Mollman
21 Sep 2016
GBRF did put 92s on Felixstowe - Trafford Park flow for a while pre-Sleeper. They might be using it for that?
10 Jan 2020
York
Those were my thoughts. 92044 specifically operated 4L18 (and the return, can't remember the headcode for it) for a long period of time. A few people ive talked to think this too, and the fact that Courperin has had its chunnel Roundels removed may suggest that it's not being deployed on international services
DBS92042
13 Apr 2019
92s haven't worked the 4L18 for quite a few years now (last one worked it in 2014/5 I think), so I don't think it'll be going back to 92 haulage any time soon but I could be wrong.
I believe the Roundels were removed to help prevent rust on the bodyside? rather than the fact they weren't going to work through the Channel Tunnel (they've been removed from all of GBRF's operational 92s now).
43096
23 Nov 2015
92s haven't worked the 4L18 for quite a few years now (last one in 2014/5 I think) so, personally, I don't think it'll go back to 92 haulage any time soon but I could be wrong.
I believe the Roundels were removed to help prevent rust on the bodyside? rather than the fact they weren't going to work through the Channel Tunnel (they've been removed from all of GBRF's operation 92s now).
Correct. Removal of the roundels is part of the overhaul work that Brush have done on all the operational GBRf fleet; 92044 being the last to be done.
