From what I believe, there are signalling questions on there because the external and internal application forms are the same, Iv also heard that some hiring managers understand and prefer an N/A on a question rather than try and fudge something that you couldn’t have experienced.I think there's a danger of over-analysing the process - after all we don't even know if it's computer scored or not and you need to successfully get through the 70 questions before you get the assessments (I think!)
As you have to give examples for any of the questions that you answer yes to, I assume those will be read by a human but perhaps after the assessments have been done. Again, its just guesswork!
As it stands today Inverness has 2x grade 6 RETB workstations, 1x grade 4 NX panel and 1x grade 3 WESTCAD workstation.Does anyone know what grades are based at Inverness Signalling Centre and how many workstations there are?
But I do know they are read and not scanned by computer. Hope this helps.
Maybe both but the hiring manager definitively looks at them to choose which to invite to interview from the ones HR send him/her. So they might send him 15 and he picks say 6 for interview. How HR pick the ones for consideration im not sure .Thanks - I was pretty sure the 70 questions were checked by a person as artificial intelligence isn't really up to the job just yet! I'd just be interested to know at what point they are read - in the initial application or at the end (as part of the interview selection)? Maybe its both
I would say it’s maybe the other way around? Only for the fact that When I applied the tests were sent out almost immediately, and then once they had expired and I applied again they were out to me straight away. then they have a look at the applications of those who pass the benchmark hence the under consideration email, keep going though, took me over 2 yrs . I think what made the difference on my applications was I spent a bit more time on the questions I could answer and then for the first time got through to the consideration by the hiring manager and then didn’t get interview ! so next time I spent ages on it. Re wording everything and making sure the emphasis was on safety.Application 20 failed with 1 still on test passed.
My understanding is you do the 70 questions and if you get past this you do the online test, which goes to test passed and application under consideration. If im getting this far is it my test score letting me down as its not high enough for the top 5. Almost a year now since i sat it so will i do it again in august automatically or can I ask to redo it again?
Not seen any jobs for a while in the yorkshire region im guessing most have been filled and people not moving on.
Enjoy reading on this forum, seeing people get accepted, passing on information to help others, knowing the hard work and advice taking pays off.
Na dont worry yet m8,they can take up to 6 weeks i thinkMy application is still stuck on Test Completed
Should I be getting worried after nearly 2 weeks?
I got 1 on test completed since 20th aprilMy application is still stuck on Test Completed
Guys word of warning - check out the East Midlands Trains Trainee Driver threads last post today.......
Be under no illusion we are being watched, as a result I’ll be withdrawing from this thread..
Best of luck all...
Best of luck all...
That was my thought as well! Either way it’s not an issue. I hope NR do actually monitor these threads as they’ll get an understanding of how people are finding the recruitment process.
