Kauntrilla
It's not a bad thing if u have second chance. U dont have to do all tests again. Only fails to do again
Not true unfortunately. I had passed all paper and computer tests exactly 12 months previous, but as I’d failed the MMI the test centre I visited made me do the lot again, in one day. Some will accept the tests passed, but it is up to the TOC or FOC.It's not a bad thing if u have second chance. U dont have to do all tests again. Only fails to do again
Northern Tech it is very confusing. There is no clear cut.Not true unfortunately. I had passed all paper and computer tests exactly 12 months previous, but as I’d failed the MMI the test centre I visited made me do the lot again, in one day. Some will accept the tests passed, but it is up to the TOC or FOC.
Yes I agree, but as you spend time on here and reading different threads you start to see that there are several ways assessments are taken place and it doesn’t really make for a level playing field. But there is no choice for the candidate, you go and do what they (train company) ask you to do if you want to work for whichever company You have applied to. As an example I went through the assessment process for one company last year where I had a Driver Manager Interview (DMI) first before being invited to psychometric testing. The tests were then split so I did Paper Test first, passed that so invited to computer tests and MMI a month later at a different location (passed all except MMI). Scroll on a year and I make the sift with another company, but they do testing before DMI, even though I had the paper and computer passes I had to sit ALL of them again, and with a life lost first time, this was my last chance.. Passed thankfully but I’d rather have just had the MMI to do, but it was what it was… So many different versions, some easier options than others, and some seem to get an easy MMI and some get a grilling, you just have to make sure you are ready. So use the search bar on this forum, and learn as much as you have time to learn beforehand and give yourself best chance to pass.Northern Tech it is very confusing. There is no clear cut.
Thank you for the quick for the reply.Most of the info you require is readily available on the forum. There is a sticky thread at the top that shows the TOC names and the depots they work out of. The threads at the bottom show the most recent threads at the top and even in the first few there are trainee driver jobs, such as Freightliner. You need to just read and read some more.. open up the threads at the start page and most will show the original advertisement which usually show pay ranges for starting and through to the end wage. They vary massively. To get into this job, I’d say that the more you know the better! I started looking a few years back, and my first application must have been horrendous! I’m sure there are a few lucky people that nailed it first time, but I bet they are few and far between. This forum is like a goldmine of info, but you need to spend some/a lot of time reading through it. Use the search bar for anything you want to know specifically, ie DOO, FOC etc. Good luck.
NorthernTech was very gracious in replying so quickly and giving you a thorough run down of how this forum works and of course there is always Google which often refers back to this forum anyway!Thank you for the quick for the reply.
I am doing my best to find the answers amongst the many threads however there is just so much information it is a little overwhelming!
Is there a way to share a hyperlink with me at all that would take me to where I should be looking? Alternatively if anybody might be able to share some direct answers to the questions above I would appreciate this very much?
I passed AART this month. I used How2become test but it wasnt close to the real test.The closet thing to the real test is a download from Traindriverinfo.com.I thought I have done very badly but still manage to pass. I dont know how..In real test u have to only look for 5 things nothing else.Great thread first of all, it has been very helpful in finding out what to expect in the recruitment stages.
I haven’t been able to find out much about the AART (perception) test. I have a copy of the how2become AART test and have found it surprisingly difficult! For those who have utilised the how2become program and undertaken the drivers assessment, would you say it is a good representation of what the test is like on the day?
I’ve got both of these tests and frankly the How2 packages are terrible compared to Traindriverinfo. The latter is as near to the real tests as can be and there will be no surprises on the day!I passed AART this month. I used How2become test but it wasnt close to the real test.The closet thing to the real test is a download from Traindriverinfo.com.I thought I have done very badly but still manage to pass. I dont know how..In real test u have to only look for 5 things nothing else.
When is ur assessment mate?I’ve got both of these tests and frankly the How2 packages are terrible compared to Traindriverinfo. The latter is as near to the real tests as can be and there will be no surprises on the day!
It all depends on the company that you end up working for - some companies work over four days, and I believe some work over five days. Each TOC will have its own shift limit and driving time limit under normal circumstances.Hi guys I am interested in becoming a train driver, I am aware that train drivers work 35 hours a week if I am correct. Just wanted to ask how many hours a day train drivers work but also how many days a week do they work and do they work on a roster?
Thanks.
It all depends on the company and depot in question - but they will all have a roster, which you will enable you to work out which shifts you will be doing, quite a while in advance.Hi guys I am interested in becoming a train driver, I am aware that train drivers work 35 hours a week if I am correct. Just wanted to ask how many hours a day train drivers work but also how many days a week do they work and do they work on a roster?
Thanks.
I used the how2become software. Certain bits were helpful, others not so helpful.I have my assessment coming up and am doing some prep work... wondering if I should invest in a support package?
I have seen a couple of comments on these forums relating to How2Become and also something called Traindriverinfo.com. Traindriverinfo appears to be preferred option to get as close to the real thing however that URL for me doesn't exist? Can anybody add some clarity or even better the actual URL? Thanks in advance.
That must be different from the ones that I used, mate. There was nothing like that on mine.It gives you a breakdown of all times and stats from the tests. ie avg time per row etc
I’m just using the one on this forum.That must be different from the ones that I used, mate. There was nothing like that on mine.
Ah right. I was referring to the how2become.I’m just using the one on this forum.
Every time you do a test you click on ‘Sheet Stats’ at the bottom. That brings up each sheet and you can highlight omissions and fastest rows etc
