dk1
Looks like the 0800 Ipswich to Peterborough was so overcrowded it had Manea & Whittlesea calls removed. The following 0958 departed Ipswich 9E for the same reason. Will wait time at Bury. Those Stadlers can't come soon enough.
Business is brisk this football season. Can only get worse at Ely with the lack of trains across the Fens today.They drafted two double deckerbuses in to supplement the 09.58 too!
Is there a gap in the Cambridge diagram for refuelling?No 745s for a little while yet. Monday's to Friday's you'll normally catch a 755 on the Cambridge diagram starting with the 06:33 & on what was NC37 short set diagram on the Wherry Lines.
Yes some of the unit diagrams are built around being 755s requiring fuel. That particular train was also changed as cannot reliably form the 1240 due to its incoming path over Trowse Bridge being taken now by the down Ni90 service.Is there a gap in the Cambridge diagram for refuelling?
I've been working through the public timetable & the 1237 arrival at Norwich "could" form the 1240 to Cambridge but it's probably a different unit off Crown Point.
I'm trying to get to Norwich or Cambridge to ride the 755, but I can't leave Chelmsford until after 0930......
TIA for any advice, DC.
Next Norwich to Cambridge departure should be 1540.That train will run 1405 to Lowestoft and return then run to Cambridge and back 2 times,if it's the same as yesterday.Is there a gap in the Cambridge diagram for refuelling?
Stadlers out, several 158s on hire & the short hauled set. Norwich is where it's at guys
NC73 diagram looks like this:Is there a gap in the Cambridge diagram for refuelling?
Location Arr Dep Code
Crown Point 06+00 5K59
Norwich 06+10 06.33 1K59
Cambridge 07.53 08.09 1K60
Norwich 09.30 09.40 1K67
Cambridge 10.56 11.09 1K68
Norwich 12.37 12+45 5K68
Norwich Crown Point Recept 12+48 13+20 5J78
Norwich 13+24 14.05 2J78
Lowestoft 14.49 14.57 2J81
Norwich 15.33 15.40 1K83
Cambridge 16.56 17.10 1K80
Norwich 18.29 18.40 1K91
Cambridge 19.58 20.19 1K88
Norwich 21.38 21+56 5K58
Crown Point 22+06
Very busy day at Norwich then I guess. One of the big positives when the stadlers come online, the regional sets can come in from lowestoft/yarmouth and be timetabled on to cambridge as they're all the same units rather than the current miss match of sizes and standards
That assertion doesn’t exactly stand up to detailed scrutiny. Go and have a look at the size of the fleets at privatisation and what they are now.GA seem to be one of the few TOCs actively doing something about their shortage of rolling stock and capacity. There has been a trend since privatisation to order the minimum new stock for services and not much buffer to add capacity as required.
Very questionable with Anglia Railways. We had 17 DMUs at privatisation compared with 26 now. On the Intercity front there was a reduction when going over to longer mk3s (load 10 now is equivelent to load 11 mk1/2s) and the loss of boat trains. Intensity of work now however is far greater.That assertion doesn’t exactly stand up to detailed scrutiny. Go and have a look at the size of the fleets at privatisation and what they are now.
They can keep the 379s if that is so, but I think careful diagramming in the timetable recast could be the answer and making sure service gaps aren't too large.I reckon they haven't ordered enough.
Surely there must be a better way than checkered film? Blinds, curtains or even a uniform translucent film (at the expense of phone signal) would be preferable for me. Like with contravision, my eyes doesn't know whether to focus on the view behind or the grid pattern.
Thanks, I'd guessed that it had lost it's path.Yes some of the unit diagrams are built around being 755s requiring fuel. That particular train was also changed as cannot reliably form the 1240 due to its incoming path over Trowse Bridge being taken now by the down Ni90 service.
Was an enjoyable experience,unlike the 1748 class 153 back from Lowestoft!
indeed. I was lucky enough to get the flirt today(755/4), and I must say they are pretty impressive.Stadlers out, several 158s on hire & the short hauled set. Norwich is where it's at guys
NC73 diagram look like this:
Code:Location Arr Dep Code Crown Point 06+00 5K59 Norwich 06+10 06.33 1K59 Cambridge 07.53 08.09 1K60 Norwich 09.30 09.40 1K67 Cambridge 10.56 11.09 1K68 Norwich 12.37 12+45 5K68 Norwich Crown Point Recept 12+48 13+20 5J78 Norwich 13+24 14.05 2J78 Lowestoft 14.49 14.57 2J81 Norwich 15.33 15.40 1K83 Cambridge 16.56 17.10 1K80 Norwich 18.29 18.40 1K91 Cambridge 19.58 20.19 1K88 Norwich 21.38 21+56 5K58 Crown Point 22+06
Drivers are having to shut off power & check as so easy to speed in places where it would never be possible. Superb bits of kit & even the anti type stalwarts at the depot have been won over.indeed. I was lucky enough to get the flirt today(755/4), and I must say they are pretty impressive.
definitely a huge upgrade on the sprinters, and they are very quick out of the blocks.
acceleration wise they are up there with voyagers/meridians
You'd hope they diagram the 3 and 4 cars sensibly rather than mix them all up like the XC 2 and 3 car 170's.
Next weeks plans are being made, probably Nor-Low & return, then Cambridge & back.
Sure is but who cares? Thrash!!!!Well, 2600+ hp is a bit OTT for a light-weight 4-car DMU.........
