About Enviro 400
mhlam307
5 Apr 2022
Cardiff
So recently I’ve been fascinated by Enviro400s, but I’ve been so frustrated when I come to try and distinguish between variants:
ADL E40D
ADL E40H
ADL x BYD E400EV
Scania Enviro400
So what I managed to distinguish out will be the Scania, due to their long rear parts overhanging; however, I’ve been trying to look at the positions of the vents but found out they may be of different style and at different position (say a 57-plate E40D vs a 60-plate E40D)
Another method I’ve been trying is looking at the axle. What I heard was for the pre-MMC versions, all of them use Dana axle; but after that, ZF-axle have been used on Diesel version and Dana axle for hybrid version. However, I’ve managed to see ZF-axle on pre-MMC and Dana axle on E40D MMC !!
God all these are so frustrating, and please would anyone teach me how to read the VIN codes of the Enviro400 series? Thanks a lot mates!!
pm2304877
3 Aug 2023
Roby
ADL E40D
ADL E40H
ADL x BYD E400EV
Scania Enviro400
So wh
ADL E40D
ADL E40H
ADL x BYD E400EV
Scania Enviro400
ADL E400 is a body, as fitted to other chassis such as Scanias.
ADL E40D are diesel models
ADL E40H are hybrids.
BYDs with ADL E400 bodies are electronic buses.
The FCEV variant is hydrogen version. Merseyside is still waiting for 20 such which originally were 22-plate!
However Stagecoach s 115xx and 116xx are classed as E40D yet they are supposed to be hybrid. That is where the confusion lies.
mhlam307
5 Apr 2022
Cardiff
God there is still a hydrogen variant!
What I wanted to do was to identify each model from their exterior. Yet it is a really confusing task.
Surreyman
29 Jan 2012
You haven't yet mentioned varying lengths - 10.2, 10.6, 11+m (and yes these dimensions vary slightly over time depending on the age and model).
Self correction - 10.6 should be more like 10.9m.
JD2168
11 Jul 2022
Sheffield
Scania Enviro 400 has no lower rear window & has more half windows compared to normal.
Enviro 400 Hybrid have the rear upstairs seats further forward compared to normal with a box for the batteries behind it, the rear blind is also in a different place on the upper panels rather than around the window. This is due to the normal placing being where the batteries are. There are also additional vents on rear panel’s between windows due to the batteries.
Older Enviro 400 on a Trident chassis has the rear side radiator grille on the near side, the more newer ones after 59 plate are on the offside.
After 12/62 plate the Enviro 400 lost the offside lower half window, the registration plate went to the rear bumper area rather than above the lower window with the rear blind relocated to a central position above the rear window.
Russel
30 Jun 2022
Whittington
The top deck rear window changed from a rounded shape to a standard rectangle quite early on too.
TR673
4 Oct 2019
Please correct me if I’m wrong (as I’m not 100% sure myself) but the diesel, ADL-chassis Enviro 400s produced until 2006/7 are more-or-less facelifted ALX400 Tridents with the same chassis and engine, and the ones from 2007 to 2009 use an amended Trident chassis with 6.7 litre Euro 4 engine (which uses AdBlue so there's an extra filler flap on the offside). These both have the radiator on the nearside.
Then from later in 2009 the new E40D chassis came in with a Euro 5 engine, and the radiator moved to the offside.
The E40H hybrid has an engine grille on both sides, I think. Some hybrids appear to have a hexagonal pattern in the grille, but not all?
Mikey C
11 Feb 2013
Yes Lothian has a sizeable number of them.
Stagecoach in London had a few as well (not my photo)
Also, there's the original E400 body
The "replacement" E400MMC
And the E400 City which incorporates a few styling features of the London New Routemaster
The E400 BYD electric buses have the E400 City bodywork, the B5LH above is E400MMC bodywork
MCR247
7 Nov 2008
To further add to the confusion there are lots of Enviro 400 City hybrids as well as the Enviro 400 MMC hybrids
M60lad
31 May 2011
Also not forgetting the MAN E400s that Stagecoach Manchester had until recently before they were transferred out
Mikey C
11 Feb 2013
I don't think they look difference from the other E400 Scanias, but Reading Bus has gas powered examples
route101
16 May 2010
I believe Stagecoach West Scotland have E400 Scanias. They sit higher up.
Why is there E400 MMC and E400 City?
Russel
30 Jun 2022
Whittington
Always found it odd that only one E400 was ever built on the B7TL chassis.
I've used the East Yorkshire Volvo B9TL E400s in the past and it's always strange to be on an Enviro400 that sounds like it should be a Wright Gemini!
mhlam307
5 Apr 2022
Cardiff
Woah that’s really detailed guide! Thanks a lot!
PS. Mind if I ask whether you were from Hong Kong?
From what I read, E400City was to compete with the then dominating Borismaster in London. That’s why the early ones were only available in London. Not sure if there is someone outside London possessing hybrid versions of E400MMC though
JD2168
11 Jul 2022
Sheffield
I am from Sheffield in South Yorkshire.
The E400 City which Blackpool Transport has a sizeable fleet of has a part glass staircase & panelling which goes to the top of the upstairs windows. The E400MMC does not have this feature. The E400 City front end is also more rounded particularly the bottom of the front windscreen.
