markymark2000
I believe that it isn't requested else that would rule out most operators.Of course if the railway contracts toilets they are in breach of contract by doing so, so always be sure to report it if you see this done.
Toilets are available at stations. Trains can run without toilets so why can't coaches. Merseyrail have no toilets for example on trains.Perhaps it needs to sort that out, then, because Crohn's and urinary frequency issues are a disability and are also more likely with age, so failure to ensure the provision of toilets when these are normally provided on trains is both age and disability discrimination, and as most coaches have toilets ensuring they are in use is definitely a reasonable adjustment.
So making things easier for coach companies is more important than passenger comfort in your view.
That speaks volumes about the coach industry if you work in it or that's a general view.
How would you like to clean someone else's human waste off the toilet wall? I can put you in touch with a few people if you fancy giving it a try. It's a regular thing to happen on rail rep for some odd reason.So making things easier for coach companies is more important than passenger comfort in your view.
That speaks volumes about the coach industry.
To be fair there are trains running around with no toilets on board whatsoever. Not sure what that says about the railway industry!
Who's problem is it then? Driver can't control who uses the toilet if it's unlocked as the driver should be concentrating on the road, not being a toilet monitor.That isn't my problem.
If people can't be trusted to use the toilets, they get locked. Same happens with all public toilets. If people trash them, they get locked and/or taken away.
A friend of mine is a coach driver. Following a recent trip to Blackpool (IIRC), the coach was that bad they had to dump it back at the yard with both doors open to air it out before they could even think about cleaning it.I completely understand that. Sadly people behave like animals. I’ve heard some truly shocking stories on the railway and can imagine coaches are worse given the demographic using them (no offence intended, but it’s true).
And even then they pretty much had to don HAZMAT gear...
I very much agree. TOCs need to ensure that rail replacement vehicles either provide accessible facilities or provide taxis as alternatives, with the instruction to stop at services when the passenger requires it.Perhaps it needs to sort that out, then, because Crohn's and urinary frequency issues are a disability and are also more likely with age, so failure to ensure the provision of toilets when these are normally provided on trains is both age and disability discrimination, and as most coaches have toilets ensuring they are in use is definitely a reasonable adjustment.
I'm sorry to her that but, as ever, the answer isn't to punish all of the other passengers by a lack of toilet facilities,A friend of mine is a coach driver. Following a recent trip to Blackpool (IIRC), the coach was that bad they had to dump it back at the yard with both doors open to air it out before they could even think about cleaning it.
Some people do have to do it, though. And generally get paid a pittance for doing so.
You then need 2 buses per trip to provide suitable capacity and also I'd argue it's not safe for wheelchairs to be moving into accessible toilets while the bus is in motion.I very much agree. TOCs need to ensure that rail replacement vehicles either provide accessible facilities or provide taxis as alternatives, with the instruction to stop at services when the passenger requires it.
Coach companies provide what is requested. Toilet access isn't needed thought even on private hire, toilets get locked out sometimes. It's down to the individual driver.The coach company.
I'm sure not providing wheelchair access is also more convenient, but the law provides otherwise.
The job of coach driver doesn't including cleaning human waste of walls. It involves driving coaches and keeping passengers safe.Some people have to do unpleasant jobs - such is life.
It happens everywhere. If people act like tramps, privileges get removed. Whether that be throwing rocks at buses, the route get removed. If toilets get trashed, they get removed. If the local play area gets damaged often, the items get removed.I also understand this, but it isn't an excuse for disability discrimination. As for public toilets I do think the statutory duty to provide needs to be reinstated on Councils because non provision in public spaces blocks a considerable number of the population from using them - it hits three protected characteristics - gender (a man can urinate in a bush), age (more likely to have frequency issues) and disability (e.g. Crohn's). I can't think of much else that gets that many.
Indeed.
