No WTT traffic, just the odd diverted ECS!The new infrastructure will provide a full electrified diversionary route……..
I bet the freight lobby would love that level of influence and string pulling. London Gateway springs to mind here.
It will also directly link the existing OLE infrastructure on the GWML to the rest of the electrified UK Rail network for the first time.
Electrically, yes, but signalling and other limitations means that only class 345s can use that link.Is this valid? The GWML is already linked to the Crossrail OLE, which is definitely part of the "electrified UK Rail network".
They can all be accessed via the NLL (minus MML) although WCML needs a reversal at Kendal Green Turnback.Electrically, yes, but signalling and other limitations means that only class 345s can use that link.
With the new link at Acton the GWML will be connected to the NLL and anything further east across London, for general traffic.
There will still be electric gaps to the WCML, MML and ECML networks.
Unlikely, as for some bizarre reason they’re not doing the South West sidings.Is it likely that GWR's 387s would use this line during future closures of the main line?
Unlkely, GWR will continue to use 800s into Euston.Is it likely that GWR's 387s would use this line during future closures of the main line?
Reversing at Willesden Junction gets you to the WCML, the North London incline connects directly to the ECML. There are theoretical routes to get to the MML (admittedly unlikely to ever be used)There will still be electric gaps to the WCML, MML and ECML networks.
Finding a gap at Kensal Green to get onto the City lines would be fun...Reversing at Willesden Junction gets you to the WCML, the North London incline connects directly to the ECML. There are theoretical routes to get to the MML (admittedly unlikely to ever be used)
You can reverse in the turnback.Finding a gap at Kensal Green to get onto the City lines would be fun...
Oh yeah, wasn't pointing the finger at you, sorry!Don't shoot the messenger please! I just put in quotes per forum rules directly from the Network Rail Document.
The NR press release thing was specifically about OLE though. Maybe I'm being picky, but I feel like I'm allowed to if it's NR.Electrically, yes, but signalling and other limitations means that only class 345s can use that link.
It was a NR press release and Crossrail central area isn't NR infrastructure, so if by "network" they meant their own network, then it was accurate.The NR press release thing was specifically about OLE though. Maybe I'm being picky, but I feel like I'm allowed to if it's NR.
The reversing siding which needs a huge margin to get out of as you conflict horrendously with everything else, is only around 270m long and needs a freight train to be top and tailed? About as useful as a chocolate fireguard to be fair.You can reverse in the turnback.
The question was about access to locomotives to the GW. A light engine or ECS would manage that siding easily.The reversing siding which needs a huge margin to get out of as you conflict horrendously with everything else, is only around 270m long and needs a freight train to be top and tailed? About as useful as a chocolate fireguard to be fair.
Electric trains could reverse at Camden Road or Caledonian Road and Barnesbury, although the margins won't be any better. That would also allow routing via Primrose hill if the westbound path via the NLL wasn't available.The reversing siding which needs a huge margin to get out of as you conflict horrendously with everything else, is only around 270m long and needs a freight train to be top and tailed? About as useful as a chocolate fireguard to be fair.
So no use to freight at all then effectively.The question was about access to locomotives to the GW. A light engine or ECS would manage that siding easily.
Many components from Series 1 OLE were subsumed into Network Rail's UK Master Series. It's why there's a lot of F+F kit on new and refurbed stretches of electrified track well away from the GWML including up here north of the border.Surprised to see that they're using the GWML style Series 1 cantilevers, instead of the stuff used on the MML. Does anyone know the reasoning for this? Did they just have some lying around from the cancelled great western bits?
Well it does seem weird, but Modern Railways finally have a brief article and confirms Acton Bank is being wired. It does say that they key reason is to allow 345 stock from the Elizabeth line to move. Also says it is a key freight artery.
Hasn't the work already started?Well it does seem weird, but Modern Railways finally have a brief article and confirms Acton Bank is being wired. It does say that they key reason is to allow 345 stock from the Elizabeth line to move. Also says it is a key freight artery.
Exactly. Yes. Quite a few months ago. Modern Railways are very late in reporting!Hasn't the work already started?
