Advice required please
Discussion in 'Railway Jobs & Careers' started by Des587, 26 May 2015.
Thread Status:
  1. Des587
    Des587 Member
    66
    21 Mar 2015
    I recently went for a movements controller job where I had to do the train drivers assessment. Unfortunately I wasn't successful, however I have been told that I do not need to sit the assessments again. Does anyone know how I go about applying for trainee train driver jobs as there seems to be an abundance of internal recruitment programs. Is it worth contacting individual TOCs and FOCs stating I have carried out and passed the preliminary (mandated) assessments ( inc MMI).
    Many thanks in advance for your advice.
    Rail Forums
  3. RBSN
    RBSN Member
    247
    14 Jul 2014
    Which assessments didn't you pass?
  4. Des587
    Des587 Member
    66
    21 Mar 2015
    The final interview with the Depot Operations Manager, passed all the driver assessments.
  5. RBSN
    RBSN Member
    247
    14 Jul 2014
    Oh right. I believe (someone correct me if I'm wrong) after passing the assessments you have a set amount of time before you would have to re-sit the assessments. Different ToCs have different set times.
  6. redbutton
    redbutton Member
    447
    5 Sep 2013
    Just keep an eye on the jobs websites of the TOCs in your area. Trainee vacancies are usually posted online. Generally, it's only worth submitting speculative applications if you're a fully-qualified driver trying to change TOCs.
    Your assessment results are good for up to five years, but some TOCs won't accept results older than three. Some also require "enhanced" pass marks which you may not have. However, the rule is that you can only fail twice. You can take the assessments as many times as you want as long as you pass.
  7. daddy_badger
    daddy_badger Member
    243
    21 Mar 2013
    52.8248° N, 2.0281° W
    Its 6 months before you can resit. 12 months lifespan on current pass so good luck with finding a vacancy. If its not mentioned on here then keep an eye on individual tocs websites.
    some tocs may ask you to resit certain tests dependent on yourscore.
  8. SPADTrap
    SPADTrap Established Member
    2,126
    15 Oct 2012
    Mods delete please
Thread Status:
Share This Page
