Airport codes
cdonnigan
15 Jan 2011
same as station codes same rules apply four letter code And/or three letter codes must be in capital letters. If you cant think of another code then open floor. So to start lets go with LGZA i want full airport name not nickname
WestCoast
19 Jun 2010
South Yorkshire
So, just to clarify, is this IATA (3-letter, more common for the general public) or ICAO (4-letter, used in flight operations) codes? We've got a mixture in the replies!
I think this is easy NRT
Narita International Airport (it's not officially called Tokyo-Narita), that's an IATA code.
Open floor.
furryfeet
17 Apr 2008
Correct. But not for much longer.
Why is this ? Is the airport being closed ?
Another code
EIS / TUPJ
If anyone could state
a) the length of the runway in metres
b) the largest business jet which can land and takeoff from there I would be most interested.
deltic1989
21 Sep 2010
Another code
EIS / TUPJ
Thats Beef Island in the British Virgin Islands, Runway Length is 3500ft (1066.8 metres). No details on the biggest aircraft its possable to land there but its normally served by ATR turbo-props.
4SRKT
9 Jan 2009
Isn't this sort of quiz kind of, well, pointless when everyone's sitting at home on his own in front of his computer and nobody can be 100% sure that everyone else isn't just looking up the answers? It's like my trademark postcode quiz; it has to be done face to face.
Xenophon PCDGS
17 Apr 2011
The only reason why I posted the last clue was that a visitor from that country had been in a delegation to one of our projects. This was his local airport and although the OP stated the 4-letter code, I gave both the 3-letter IATA code and the 4-letter ICAO code, in case some members were more familiar with the 3-letter IATA code.
In answer to the question that you have raised, I must confess that the quiz had been somewhat quiet of late. What do you propose should be done?
Xenophon PCDGS
17 Apr 2011
Moving away from ICAO codes, what does Liverpool John Lennon have in common with Gatwick?
Do I take it that OENG no longer needs solving and the quiz is now assuming a new entity?
If it is, a new thread with a set of rules should be set up, so as not to confuse matters with this particular quiz, which is actually called Airport Codes.
SwindonPkwy
2 Aug 2011
Swindon.
Sorry, I completely missed OENG. Najran, Saudi Arabia. Pretty obscure, long runway, very few operators. Does it have a military purpose or is it a Saudi vanity project?
Xenophon PCDGS
17 Apr 2011
Your solving of the clue was impeccable and Narjan is classified as a "domestic" airport, but as you rightly point out, being in an obscure region with very few operators actually using it and possessing a very long runway, does leave certain "other" options open to it, that I shall leave open to your imagination. I should imagine the Mossad have much detail on this particular airport in their records.
Do you now want to set the next 4-letter ICAO code for solution?
SwindonPkwy
2 Aug 2011
Swindon.
My four letter code is RPVT but I also have a question regarding ICAO codes. I vaguely know that the first letter is a continent or region, as in E for Europe. But my question is this: does Antarctica have any ICAO codes? Aircraft land there and have to log flight plans. If not, what is the minimum criteria, control tower/radio frequency/navigation beacon? I guess a permanent runway would be a start, as well.
On the subject of Narjan "Domestic" Airport. A Google Earth search reveals a large terminal and second runway under construction. Also, very evident are 'dispersal' stands at each end of the runway. No sign of any F15's though.
Xenophon PCDGS
17 Apr 2011
I will answer you as follows:-
RPVT is Tagbilaran airport that serves Tagbilaran City,Bohol Province, in the Philippines. It is rated as a principal class1 airport.
With regards to Antarctica, there is a special agreement that only allows flights by air there to accredited research stations, of which many countries have there. Britain has four such landing fields for its research stations:-
Fossil Bluff, George VI Sound....................Skiway
Halley Station, Brunt Ice Shelf..................Skiway
Rothera Research Station, Rothera Point.....Airdrome
Sky Blue, Ellesmere Land..........................Airdrome
My next clue is SEPV
SwindonPkwy
2 Aug 2011
Swindon.
Okay, I'm going to do this without Google. I think S is going to be South America.
Port Stanley or South Georgia?
Failing that, I would go E for Ecuador and since I don't know the capital, how about the Galapagos (spelling?) Islands?
