Oh nuts
I just brought my long leg tickets. New street - ribblehead return (I did select YPR, but as it's before 10am i don't know if it's valid) and on the day I'll get an alb-bhm (about £6) and a dent-ribblehead single (can't be too much)
Birmingham Stns - Ribblehead SVR £33.80 Route Any Permitted 8A Valid Any Train
Albrighton
.........- Ribblehead SVR £33.80 Route Any Permitted 8A Valid Any Train
Birmingham Stns - Ribblehead SVR £40.35 Route Any Permitted 8A Valid Any Train
Albrighton
.........- Appleby SVR £43.10 Route Any Permitted 8A Valid Any Train
Albrighton
.........- Appleby SVR £32.40 Route Manchester 8A Valid Any Train
Albrighton
.........- Carlisle SVR £41.40 Route Any Permitted 8A Valid Any Train
.........- Carlisle SVR £44.90 Route Lancaster 8A Valid Any Train
So, Tom thinks that a ticket to Appleby is valid via Carlisle? I have checked the RG and can't find that is the case. Although guards will accept it I'm sure.
RPs for Albrighton are: Shrewsbury and Wolverhampton. Both pass the fares rule.
RPs for Appleby are: Carlisle and Hellifield Group. Carlisle FAILS the fares rule, but Hellifield is fine.
using Shrewsbury as a routeing point, valid maps are:-
Hellifield Group Shrewsbury BD BD+EH BD+NC
using Wolves as a routeing point, valid maps are:-
Hellifield Group Wolverhampton BS+EH BS+MH BS+NC
BD allows travel via Manchester and Hellifield.
BD+EH allows you to go via Blackburn and Hellifield (for the rare occasions when such trains exist)!
BD+NC allows travel via Preston and Lancaster
BS+BH and BS+MH are pretty much the same as BD+EH
BS+NC is pretty much the same as BD+NC
nutter - why the need for seperate Albrighton-Brum and Brum-Ribblehead tickets? if you need to go to Brum, an Albrighton-Ribblehead IS valid via Brum providing you do not double back (e.g. you can return via Walsall/Rugeley), but if you want to double back for some reason just get a Wolves-Brum for the bit where you are going back and forth to Brum.
I'm a bit confused by why you may think it may not be valid.
The ticket code is 8A which is "Valid by any train" and they SHOULD have told you this at the ticket office.
In addition, even if the saver did have restrictions, you would be able to travel at peak time on Virgin services (and, it seems, CrossCountry too) due to the railcard easement.
