[Another error] .Sta command
Nick
8 Jun 2005
Code:
.Sta Derby;10.3745;10.3800; ;-1;0; ; ; ;15;24,
Is part of my route code, for a station, named for example reasons Derby (cause its short). I have followed instructions to get the command correct, but when I try to run bve4 it thinks the 24 at the end (relating to the percentage full of the train) is the sound I want it to play. Can anyone give me the correct way that code should be displayed in BVE4 to prevent a error?
Ta.
Dennis
8 Aug 2005
Trowbridge
should be
.sta Derby;10.3745;10.3800; ; -1;0; ; ;15 ;24,
probably just miscounted the number of ; required, easy mistake to make.
Station syntax for BVE4 should be
stationname; arrivaltime; departuretime; leaveblank; doorside; stationsignal; leaveblank; arrivalsound; minimumstoptime; fillfactor; startingsound;timetableindex.
At least BVE4 gives you a clue what the errors are - much easier than BVE2.x
