Another problem!
9 Nov 2005
I redownloaded Edinburgh to Aberdeen becasue of the blurriness and now I get an error message, aswell as the blurriness...
"C:\Program Files\mackoy\BVE4\Railway\Route\Edinburgh to Aberdeen\43.csv(2768 ) : Input string was not in a correct format.: Track.freeobj 0;22+C27684"
Any help please? :(
9 Apr 2006
London, UK
It seems that a freeobject command got corrputed...
Try this- Open up the route file and find "Track.freeobj 0;22+C27684" once you found the matching command, delete the end bit and change it to ".freeobj 0;22, " (without quotes) then save and reload.
66526
9 Nov 2005
Well the error message doesn't come up but the cab is still blurry.
nutter
13 Nov 2005
Albrighton, Nr. Wolves, Shrops
In my experiance it's because you either have a poor graphics card/ram etc. or you have to many other programs running in the background (task manager)
5 Jul 2005
House
When I installed mine I installed it to the BVE4 folder as that was default. The scenery ddin't work but the cab was fine, then I installed everything into just the plain BVE folder and now it's fine. See if that works if none of the above do.
Simon_G
19 Mar 2006
Just to put things in context, Edinburgh-Aberdeen is a very long route by BVE standards: the HST run occupies nearly 210MB of RAM when loaded. So it isn't surprising that it causes difficulties for some users!
BTW, I get the same syntax error with both the 170 and HST routes. Has anyone contacted Don to alert him to this problem?
