My return must be no later than the 2210 to get the last train from Manchester to Bolton, so the ticket must be OPR.
An OPR is a
Super Off Peak Return; we do allow codes to be used,
but it's best to define them the first time they are used
and of course they must be correct
The full range of fares for Bolton (BON) to Liverpool South Parkway (LPY) are as follows:
https://www.brfares.com/!fares?orig=BON&dest=LPY
RETURN FARES
| Route
VIA MANCHESTER | Validity
1DYOUT 1MTHRTN | Adult
£27.70 | Child
£13.85 | ◊ |
| Fare Setter: TRANSPENNINE EXPRESS |
| Route
AS ADVERTISED
Restrictions
TO NOT VALID BEFORE 0830 MON-FRI | Adult
£20.20 | Child
£10.10 | |
Outward & Return: | NOT VALID BEFORE 0830 MONDAY-FRIDAY. |
| Route
VIA WIGAN | Validity
£19.80 | Child
£9.90 | ◊ |
| Route
ON DATE SHOWN | Adult
£16.10 | Child
£8.05 | ◊ |
| Route
SEE RESTRICTNS
Restrictions
B1 OFF-PEAK | Adult
£13.00 | Child
£6.50 | ◊ |
Outward & Return: | VALID AFTER 0929 MON-FRI |
| Fare Setter: NORTHERN |
Really?
Right. That seems very confusing, a pax might just buy the ticket in advance and then select the train journey wanted on the day, thinking it's an open ticket
The term "open" ticket is open to interpretation, but either means a ticket which is semi-flexible (i.e. a Super Off Peak Day Return would count), or valid to return another day (e.g. an Off Peak Return), or valid on any train to return within a month (e.g. an Anytime Return, which retains the code SOR which reflects the fact that such fares used to be called Standard Open Returns) but I've never known anyone use the term "open" to refer to the
routeing of a ticket.
I suggest avoiding the use of the term "open ticket" as it causes confusion at the best of times, let alone when you apply it to refer to the
route of a ticket!
I know I would; and I'd expect to be routed through Manchester.
When selecting an itinerary, you can check the route is appropriate and the booking site will automatically check that the ticket is valid for that route.
However if you return via a different route, for which a higher fare applies, the good news is that the on the train excess fare is half the difference between the price paid and the appropriate fare, so you are not penalised in such an event.
