randyrippley
- Joined
- 21 Feb 2016
- Messages
- 5,212
Driving north along Stanley Rd in Liverpool this evening I had the misfortune to be stopped at a junction alongside Arriva's CX58EUJ
As I waited several minutes for the lights to change I was shocked to see the right hand side of the bus repeatedly rising six inches or so on its suspension and then dropping again, on around a 20 second cycle. Effectively the body was repeatedly tilting to the left, and then dropping back down. I pulled away before the bus moved so couldn't see if the problem continued while the bus was in motion, but I'd regard the vehicle as unsafe and unfit to be on the road. The passengers must have been seasick
FWIW I noted also that of the four headlamps, one had a dipped light on, the other three (including both offside lamps) were on sidelights only.
Is this typical of Arriva's maintenance?
