Ashford to St Pancras International ticket - can I exit at Stratford International instead?
beanwalls
30 Oct 2018
Hi All,
If I bought a return from Ashford International to St Pancras International, can I exit at Stratford International on the outbound journey, but return from St Pancras?
Where I need to be is better for Stratford on the way up but when I come back a couple of days later, St Pancras is better...
Haywain
3 Feb 2013
As long as this is a ticket type that allows break of journey, such as an Off Peak Return or Anytime Return, there would be no problem with this.
beanwalls
30 Oct 2018
I think it would be an Off Peak Return, but return within one month type. I assume advance singles wouldn't allow this, but are there other types I should avoid?
Thank you for your help!
The outward portion of a Weekender Return has break of journey restrictions. The return portion permits break of journey, though.
mm333
28 Aug 2008
53.8331°N 1.7734°W
I exited and then went back through the barriers last week with the outward portion of a London-Canterbury HS1 e-ticket. No problems. I had to collect my luggage from the Premier Inn and then carry on to Kent.
