ATW have put out a letter to stakeholders, Gareth Marston may know about this.
see below. From SCRUA
According to the ATW letter the speeding up of services on the Marches line allows for these stops without extending journey duration. All will be revealed in the next SDN.
You have to consider which route carries most people - I suspect Manc - Cardiff rather than N Wales to Cardiff - there's a wonder.
Doesn't look particularly helpful for Church Stretton - reduction in services & some very long waits at Shrewsbury (up to an hour) for connections to/from Crewe. At the moment it is drect every hour.
One consideration - would it be feasible to extend the 2-hourly Crewe-Shrewsbury stopper further south (Presumably would have to run to terminate at Hereford or somewhere on HOW ). Obviously it would require an extra unit to run this but it would give a direct service at CTT and Craven Arms etc & maybe both the Manchester & the Holyhead trains can be quicker as well if the connections at Hereford & shrewsbury were reasonable.
the 13:20 Crewe arrives at Shrewsbury at 14:08.
the HOW service leaves Shrewsbury at 14:05.
Would it be feasible to combine these as a through service?
In Steam days the route was broken down into local chunks doing all stations say Shrewsbury to Hereford and the North to West Expresses that only stopped at the major stations Crewe, Salop, Hereford, Pontypool Rd. The stations that survived are the ones that according to the Beeching report earnt more than £5K per annum in passenger revenue. The Crewe to Shrewsbury locals somehow survived recommendations for closure and the North to Wests were diverted via the Midlands and a Cardiff to Crewe service (stopping all stations south of Salop instigated) these were then extended to Liverpool and Manchester in the 80's. The pattern on the route is essentially that of a long distance service providing a local service as well as a through service, overlayed over a steam era relic between Salop and Crewe.
The best option for the Marches is for the southern section Abergavenny and below to become part of the Valleys network of Cardiff commuter services. There is a turnback at Abergavenny which has not been used for around 6 years. If there was a half hourly local service to there you could speed up Holyhead and Manchester trains by cutting out stops. Whitchurch and Nantwich have crept into the "city region" influence of Manchester and rightly deserve direct trains there.
Na it was Dec 08!I think FGW withdrew the abergavenny stop back in dec 2009
I knew nothing of this! Any more info to hand?I did hear that FGW were changing the times on the London - Swansea services, so that they would leave cardiff central earlier meaning that the Milford Haven train woudnt follow about 12-15 minutes behind the FGW service.
Any more changes being brought in by arriva for the may 2011 timetable? I did hear that FGW were changing the times on the London - Swansea services, so that they would leave cardiff central earlier meaning that the Milford Haven train woudnt follow about 12-15 minutes behind the FGW service.
News to me, not even in rumour form. Given the chaos it would cause to existing diagrams, not to mention the flow of trains into and out of Pad, I seriously doubt it.
Well they could be swapping the XX15 and XX45 so the 15 goes to Swansea and 45 terminates at Cardiff?
Na it was Dec 08!
Thanks Walrus & Tony, I presume the FGW still goes via Abergaveny for an Hereford dawn start,if this is so where is its stables overnight.
M
I believe so, and it will come from SPM. Not certain but I think so! Waste of fuel eh?Thanks Walrus & Tony, I presume the FGW still goes via Abergaveny for an Hereford dawn start,if this is so where is its stables overnight.
A empty stock hst always passes through Bridgend at 03:45 and normally goes via the vale of glamorgan route to Cardiff. Not sure if this then goes to Hereford or does the 1st Cheltenham/Gloucester - London service
Waste of fuel eh?
True! Unless we had some Hereford crew be quite useful I think. Are there Worcester based crew for FGW?The other option is stable the train there overnight and taxi the crew to and from every day. Probably cost more.
According to a colleague, the FGW HST stopped at Abergaveny on its was to Hereford then London to test the traffic, although knowing the area, the traffic would be sparse, stop was due to requests,probably political local M.P?
So is the HST stabled at Hereford over night,or sent somewhere for servicing? although security of the stock comes to mind.Does ATWs Hereford station have all night staff?
If this goes ahead the 17.50 from Cardiff will no longer stop at Pontypool, so commuters finishing work at half-past five will have to wait for 2 hours for their train home.
Yeah, like hell they will. Make the service as unhelpful and unfriendly as possible and then use that as justification for further cuts when passenger numbers go through the floor.
