Track circuits have improved in that time but so have axle counters. I know there are some not so good axle counters out there and some questionable architectural decisions. However, the good axle counters are better than the good tracks now. The operational side has matured now too. There will be niche applications for track circuits but it usually makes sense to go for axle counters now.
Joint less track circuits (called joint less because they don’t need IRJs) have been around since 1967.
The current EBI Track 200 / Digital TI21 can be remotely monitored and requires significantly less maintenance compared to earlier designs.
The AzLM, K type axle counters that have been installed in my area have not been as reliable as we expected. In electronics, there is a graph that depicts reliability vs. time. It’s called a bathtub curve. Basically the number of failures may be high to start with, reliability then improves. The curve hopefully flattens to a straight line for a long time. Then as equipment ages, the failure rate starts increasing.
But due to rather a lot of component failures, poor installation, and various other problems, it’s taken a long time to get out of the infant mortality/first part of the bathtub curve.
And if a axle counter head, or it’s electric junction box needs changing, that normally takes about one hour. No amount of the signaller trying resets will get around such a failure.
So I’m not at all sure that axle counters are always better.
Track circuits cannot be duplicated, or to put it another way they present a single point failure that will ‘stop the job’ until fixed. Axle counters present opportunities to keep trains on the move with duplication or linking between sections. E.G. for the latter situation, take three wheel sensors A - B - C. Normally A and B work together as do B and C but it’s also possible link A and C such that a miscount at B can be ignored. This can be expressed in the form of an additional Train Absence Detection Control Table used to construct the data in the Axle Counter evaluator.
Note I have even seen axle counters overlaid on track circuits to increase availability following a track circuit failure, ref. Hong Kong Eastern Harbour Crossing turnback headshunt, that was 1989.
Err, yes, it is possible to have more than one track circuit on the same section of track. There are also other cheaper methods of increasing track circuit reliability.
But the current railway practices in this country don’t call for duplication for track circuits or axle counters. So both suffer from various single point of failure faults.
And as I said earlier, loss of an axle counter evaluator system will result in multiple axle counters failing, which the signaller can’t do anything about.
Obviously, the failure rate in my area is not going to be representative everywhere.
I’m just making the point that it’s definitely not a simple answer.
I was quite surprised to learn that track circuits have been around for over 100 years.
Yes, the basic track circuit as we know it today dates from about 1872.
Basic battery fed DC track circuits using shelf type relays are still in use in some places.
