I've been having a think over the last day or two about how Barking station might be reconfigured once the GOBLin service is extended to Barking Riverside. It's just a bit of musing about how things could change - I'm clearly not being deadly serious here.
Given the platform 1 bay will get practically no use once the extension opens, I decided to have a poke around and I noticed that there appears to be daylight from the end of the platform tunnel, suggesting there is unexpectedly a clear route through to the other side (abet with some minor constructs in the way on the other side).
Can anyone confirm if that happens to be the case?
If so, I was musing that you should be able to shuffle the platforms over to either give the H&C another terminal platform, or more usefully, move the GOBLin platform over between the lines to Dagenham. Downside is that you would lose the cross-platform interchange between the NR service to Upminster and the Underground, which suggests to me it would ultimately be a non-starter.
If that wasn't an issue however, then conceivably you could manage:
Platform 1 - eastbound District
Platform 2a (new bay cut into current platform 1 island) - terminating H&C
Platform 2b - westbound District
Platform 3 - Eastbound c2c to Upminster
Platform 4 - Westbound c2c
Platform 5 - Eastbound c2c to Dagenham Dock
Platform 6 - Westbound c2c
Platform 7 - eastbound GOBLin
Platform 8 - westbound GOBLin
You could further refine that by cutting a GOBLin bay into platform 7 if desired, and perhaps by utilising the current grade separation you could manage platform 6 as a single westbound c2c platform, or 5&6 as a westbound c2c island - the difficulty being getting the road through platform 4 over to the up Tilbury.
All that would enable the GOBLin to run segregated on the southern side of a 4-track formation through Ripple Lane to the new riverside branch. If the desire was to have less change through Ripple Lane (i.e. for the GOBLin to use the centre goods roads), then the GOBLin would have to use platforms 6&7, with c2c's Dagenham service using 5&8. This would put paid to any notions of a combined westbound c2c platform though.
Thoughts?
Thoughts?
