http://www.realtimetrains.co.uk/search/advanced
This is a pretty good website for train times an platform number. I believe it gets its information from the 'mainframe', it is certaintly very accurate and up to date as to a train's position. I reckon it's the best you'll get, probably just as good as the boards in stations, but as with everything not perfect, things can be changed at the last minute. Hope this helps anyway![]()
If there are alterations from the booked platform, especially in the case of STP schedules, they cannot be relied on.
At which point live maps like Traksy and opentraintimes become quite useful, provided you know what headcode it is that you need.
Perfect - have bookmarked the mobile site. You do have to know the ultimate/rather than intermediate destination but that's easy enough to learn.
This one may also be worth trying
http://iris2.rail.co.uk/tiger/
Once it is it is accurate thoughBefore it is bold
Yes. TOPS/TRUST is alive and well on an IBM mainframe in [location redacted].Do the railways still have mainframes? Although, I guess TOPS is/was a mainframe application
Educated guess? AFAIAA it shows the booked platform. Certainly at Waterloo trains stick to the booked platform unless there is good reason to change it. Even with the current situation where platforms 19/20 are blocked on weekdays and 21/22 are being used instead, there are VAR schedules in the system for trains affected.Once the platform number goes bold it is accurate at most stations BUT not all. In particular, it is not accurate at all for London Victoria. Before it is bold it is an educated guess based on the most-used platform by that train in the past however-long.
According to RTT, 2O94 1709 Weston-super-Mare to Weymouth last Sunday used Platform 1 at Bristol TM. Work that one out.
The service was most likely involved in a set swap and the platform displayed will be where the new train left from.
Should be accurate at Victoria, especially since the new data was activated. If its not then please report it, otherwise it won't get fixed. The platform number before it goes bold, as I already stated up thread, is the booked platform number as per the timetable. Not a "educated guess" you speak of.
My Local Station has the Same Platform numbers on both sides, it has 6 platforms, there's a bit of Platform Which is never used.
Open Train Times shows Platform 5, more logical. There was another train in Platform 1, a Beach Line turnround, throughout this time and as 2O94 was worked by a 3 Car Turbo there would have been no room to put another one in the Bay.
