- Joined
- 14 Jul 2011
- Messages
- 16,823
I can just about see how a tram extension to Bingham perhaps might be an idea, but I just can't understand the idea of any extension beyond Bingham through miles of sparsely populated countryside to Grantham.
Once you go to Bingham, if you truly use a tram train solution - there is little reason not to simply go the entire length of the line.
The only costs associated with going further will be new platforms/tram stop modifications, and relatively low specification 750V overhead electrification.
There is something of a false dichotomy here where people are assuming that because a tram is associated with urban travel it must only be used for that.Other larger systems already referred to around Manchester or Newcastle link large urban areas not miles of rural countryside. Comparing with Manchester, Bingham, Bottesford and Grantham do not really compare with Bury, Oldham, Rochdale, Ashton, Salford etc.
What I am proposing is to use tram trains to connect the regional services to the centre of the city rather than leaving them at a station that is clearly unable to cope with them as it is - less alone the service improvements necessary in future if the railway is to not be rendered irrelevant.
They are also within the same local authority of Greater Manchester but a line to Grantham would involve Nottingham City, Nottinghamshire, Leicestershire and Lincolnshire. It just won't happen.
Ah local government, so tax money from Grantham can be bled on vanity projects and transport improvements in Lincoln - a city I (having lived in Grantham my entire life) have been too maybe a half dozen times.
If the loading gauge width requirement is only 2.7m for the platform that is only a difference of something like 30cm, which is only about six inches per side.Both Luas and NET use Alstom Citadis, albeit different versions, so the platform height may be similar. However the Network Rail gauge I referred to earlier is the same width down to 270mm.
I think interlaced track is only used at one place for tram-platform stepping distance purposes, that being Baunatal near Kassel. It would add a couple of million to the cost of a tram-train stop.
A six inch loading bridge doesn't seem unreasonable especially if it folds in the middle as well as downwards, or if it slides out from under the floor. I wonder if this problem has come up anywhere else.
Grantham-Nottingham transport demand is currently suppressed by the awful train service and the huge traffic problems in Grantham caused by the lack of an A52 bypass. While I doubt the councils insane Millau-lite viaduct plan will ever come to fruition, if it does then that constraint will ber emoved and we will end up with A52 being enormously heavily loaded all the time.
If there is no serious public transport solution at that time then political pressure will build for a dual carriageway all the way, at which point the train is done because it will never be able to compete.
