Birmingham to Liverpool capacity drop
frodshamfella
25 Sep 2010
Frodsham
Travelled to Birmingham today from Acton Bridge, the 07.59, was packed , only 4 carriages . Turns out the 07.30 Lime Street to Euston was cancelled, so even worse than it would be. I see my.return this afternoon at 15.34 also only 4 cars rather than the normal 8. Still no 30 min service, so I'd say the full.8 car trains is needed.
It's a bit of a tide-over until the 5-car 730s are available I think? 5.730 will probably be about right for these, with the second TPH back in the busiest hours.
Grumpy Git
13 Oct 2019
On the same service, any idea why the re-introduced xx.03 off Lime St runs semi-fast between Runcorn and Crewe?
Makes my regular 'split' to Derby 25% more expensive as no stop at Acton Bridge.
frodshamfella
25 Sep 2010
Frodsham
When are these due ?? New Street shortly already full. No news on return of 30 min service ?
Jamesrob637
12 Aug 2016
The second Liverpool to Birmingham runs at present but only in the peaks.
frodshamfella
25 Sep 2010
Frodsham
Not a great idea to drop capacity, if these new new trains are not going to appear for a year or two. Christmas travel should be interesting.
SCDR_WMR
17 Dec 2017
Most hours of the week still have the same 8 car 350 worth of capacity, just split into the 2 services of 4 cars again.
Yes the 2nd service only call at Runcorn and South Parkway between Crewe and Liverpool, but technically speaking only 4 cars ever stop at Acton Bridge as its a UDS station. Still the same 1 tph for there regardless.
Once those who travel from Lime St and Runcorn notice the faster service, the stopper won't be have as bad as it's been this week.
Also, the stopper has been very full this week due to cancellations of other service rather than simply full due to the lack of an 8 car train
Not really much of a drop in capacity, just requires people to use both of he 2tph services at the major stations.
frodshamfella
25 Sep 2010
Frodsham
Yes the 7 30 Avanti ex Lime St was cancelled, so they all got on the next LNWR , which I got on, unfortunately it was only 4 carriages .
peter166
15 Mar 2010
NW
It wasn't a great start to the new timetable on Monday (11 Dec) when it was decimated with 8 services from Liverpool to Birmingham being cancelled.
0933, 13.33, 1433, 1533, 1608, 1733, 1833 and 2133
Note the 4 Hour gap in services between 1233 and 1633 !!
SCDR_WMR
17 Dec 2017
I worked the 1533 on Monday, the others are correct though. In fact, the 1533 ran the Crewe where is was cancelled but the train formed what would have been the 1608 service with those passengers still on board.
peter166
15 Mar 2010
NW
Ok, but still hardly much of a service. There were apparently 9 cancellations the other way from Birmingham to Liverpool.
What was the cause of such a shambolic service? Told at Runcorn it was a lack of train crew but no reason given why?
I was supposed to be travelling on the 1351 from Runcorn to Wolverhampton but when it was clear that 2 consecutive trains had been cancelled I got just got back in the car and drove instead.
I got there about 1515. If I had waited for the train it would have been over 2 hours later !
frodshamfella
25 Sep 2010
Frodsham
Its very poor. Connections between Liverpool and Crewe are really pretty bad 1 ( sometimes 2 ) LNWR , and 1 Avanti...thats if they aren't cancelled. Liverpool - Runcorn not much better, just the extra TFW Chester service, which will finally return to hourly this month....ooops delayed again now Jan.
SCDR_WMR
17 Dec 2017
Indeed it has been all week.
Train crew shortages on both side, but mostly New St drivers. Both Crewe and New St are at max annual leave (day and block week), Crewe also have 3 drivers in chain of care and the lack of crew wanting RDW means there are plenty of open jobs with spare turns already allocated at 7 day roster for the most part.
I don't see the service improving too much before New Year unless a bonus payment is introduced (highly unlikely)
Kite159
27 Jan 2014
West of Andover
It will be interesting to see what some of those trains will be like on Saturday with the Saturday leisure crowds heading into Liverpool [and even towards Birmingham]. 2tph is slightly better from Crewe as it gives a bigger gap as the last timetable had both Liverpool trains departing Crewe within a few minutes of each other (Avanti first followed by the LNR).
SCDR_WMR
17 Dec 2017
If train crew availability is as bad as the rest of the week then it's going to be awful
Kite159
27 Jan 2014
West of Andover
The stoppers are mostly booked for an 8 car on a Saturday
Wouldn't it make more sense for the fasts to be booked for the 8 coach sets, just to avoid the need for Unit Deselect at the various stations which can only take 4 coaches? (Considering anybody from Crewe wanting Liverpool will probably board the Avanti a few minutes ahead of the stopper)
frodshamfella
25 Sep 2010
Frodsham
The only thing is Hartford and Winsford are quite busy stations. Saturdays are always busy heading into Liverpool.
peter166
15 Mar 2010
NW
AndrewE
9 Nov 2015
Does the "modern" railway have calendar leave years then? When I joined in 1974 your leave year was based on the anniversary of you joining. I couldn't believe the stupidity of the civil service when I moved to it, which stuck with calendar years, meaning that everyone pretty well had to "use it or lose it" in December.
If you wanted to chose the worst option for the railway with heavy seasonal patronage, that would be it!
SCDR_WMR
17 Dec 2017
Yeah it's Jan-Dec for annual leave, but regardless of when your anniversary is, you'll always have the maximum leave being used in school holidays and in December. You could have it June-May and still have the same situation as now. (sans drivers on chain of care).
I never mentioned people using up before losing it as that doesn't happen at WMT, so long as you've attempted to use your floating days you can roll them over. I had to roll over 13 days last year no problem at all with rosters.
I should also state that there is 730 training and Colwich signal training being completed which compounds the lack of drivers wanting RDW.
JW4
14 Feb 2023
According to RTT
12:08 LIV —> BHM cancelled LIV —> CRE
15:08 cancelled
15:33 cancelled
17:08 cancelled
18:33 cancelled
19:08 & 19:33 cancelled LIV —> CRE
20:33 cancelled
22:17 non-stop to Crewe cancelled
At least they only had one cancellation in the first 9 hours :s
Jamesrob637
12 Aug 2016
According to RTT
15:08 cancelled
15:33 cancelled
17:08 cancelled
18:33 cancelled
20:33 cancelled
So morning was good, afternoon/evening less so.
SCDR_WMR
17 Dec 2017
I feel like maybe I should apologise for 2 of those cancelled services as I was meant to work them but an ear infection kept me off work for the last few days.
There does look to be less vacant turns at my depot this week, so fingers crossed it's a improvement on last week!
