Blackpool TPE T&C’s/ Shift Patterns
Jon H
15 Dec 2017
Hi, I’m at the assessments stage and if I pass I will be a trainee at Blackpool.
The position stated TPExpress terms and conditions could anyone explain fully what the differences are and if possible an example of the shift pattern worked.
Thanks in advance for any info.
Jon
rhys37429
3 Jun 2014
Sundays part of the working week. if you ask for it off, you have to find cover, if no cover you have to work it.
routes signed:
blackpool - preston.
preston - airport (via wigan & chorley)
preston - barrow.
traction:
class 153, 156, 158, 185.
think the earliest start is 3am ish.
Jon H
15 Dec 2017
Hi Rhys37429,
Thanks that has helped a lot does it run on like a 3 week rots basis so you can pretty much plan ahead for the upcoming months?
Thanks
Jon
driver9000
13 Jan 2008
Assuming this is a Drivers vacancy. With Sunday as part of the week it's a normal working day, if you want the day off you either swap with a colleague or take daily leave. Unless things have changed the rest day pattern is fixed for 12 months each December but the rest day pattern doesn't roll in a 3 week cycle like "old" Northern links.
Jon H
15 Dec 2017
Hi driver9000,
Thanks for your reply. I don’t mind working weekends so mich used to it now but good to see you can swap and take leave etc.
Thanks
Jon
Tractor2018
31 Jan 2018
routes signed:
preston - barrow.
I'm sure they sign Windermere too?
From memory, at the minute it's a 29 line roster - so you'd potentially know approximately 7 months of work in front of you.
Edit: earliest book on 0248; latest book off 0153.
