Blocked entrance/exit at Sheffield near ticket office
12 Nov 2020
Hemel Hempstead
I have noticed that the entrance/exit near the ticket office in Sheffield is sometimes blocked by noticeboards.
They seem to prefer to use the second entrance/exit near Upper Crust.
It seems to me to be a possible fire risk - how can I check whether they are allowed to do this?
I was at Sheffield yesterday so could have looked at this then; I am not an expert but I am a trained fire warden so do have a good idea of what may be a risk, but I am not sure when I will next be there.
If you have a concern you could contact South Yorkshire Fire & Rescue:
197 Eyre Street
Sheffield
S1 3FG
For satnav use postcode: S1 3HU
Tel: 0114 272 7202
Fax: 0114 253 2266
Email: [email protected]
PupCuff
27 Feb 2020
It seems to be an EMR thing - Nottingham station seem to love randomly locking their fire exits out of use with no signs on the door to indicate that it's due to a fault or whatever and where the alternative nearest exit is.
I've been tempted to log it through the rail industry's safety reporting website (CIRAS) it a few times.
NorthernSpirit
21 Jun 2013
By the sound of it what EMR (East Midlands Railway) are doing is highly dangerous, as you won't be able to evacuate the railway station safely should there ever be a fire - just imagine peak hour Monday morning or Friday evening peak added with a few intoxicants and what you have is an unfolding disaster before your very eyes.
AndyMike
12 Oct 2020
Sheffield
I noticed this the other day as well. It’s long been a regular thing that not all those doors are open, but I can’t for the life of me think of a plausible reason.
Harpers Tate
10 May 2013
If I had to guess - the reason would be bad weather esp. strong winds.
There are at least two other edits from the concourse as others have said. Two at the front and one by the taxi rank.
Of course, they do tend to block the one nearest the country end, which unfortunately means a longer walk to the Sheffield Tap.
MCSHF007
7 Dec 2015
Also a (slightly) longer walk to the Interchange. It's a minor (but real) inconvenience when they do this.
syorksdeano
7 Jan 2011
I believe that door is knackered and sometimes fails to shut or open.
It is a bit like the lift where "engineers" are aware and it will be repaired shortly..... Its been like 3 years maybe longer that it is getting repaired shortly
YorksLad12
5 Feb 2020
If that's the left-hand door as you face the entrance - at least since early 2018, possibly late 2017. Always a nuisance on the way out as I had to cross the stream of people heading uphill to reach the crossing point opposite the entrance to head towards Ponds Forge. Eventually I discovered the tram stop entrance and avoided the crowds ;)
johnnychips
19 Nov 2011
It’s this one. It isn’t the wind; it has been failing on and off since the previous sliding doors were replaced by folding ones.
mike57
13 Mar 2015
East coast of Yorkshire
I cant see whats on the other side of the notice board but the common sense approach would be to have some sort of indication where alternative exits are. I would have thought the risk in an emergency is that people think the exit is available and it isn't rather than not having enough exits.
We had a very similar situation at one of the offices I worked in a couple of years ago (not rail related), there was an exit which looked like the the obvious one to use in the event of fire, but it was locked for security, and the Fire Officer insisted on clear signage. There was a perfectly adequate fire exit, just wasnt obvious, a sort of error trap, which is how a lot of events turn from non threatening to serious. If its been a problem for a while then put some proper signs up showing routes, you can get a A0 poster(s) printed on a plotter for a few pounds at a print shop.
Dr Hoo
10 Nov 2015
Hope Valley
As a regular user of Sheffield I was always struck by the number of people smoking or vaping immediately outside the said folding doors. Quite apart from understandably dissuading many passengers from even attempting to use the doors for their intended purpose this also had the effect of making the doors 'cycle' continuously as the smokers lounged around leaning on the security bollards. So they probably just wore out in a matter of months.
P Binnersley
30 Dec 2018
Judging by this photo the doorway is signed as an emergency exit.
It may or may not need to be an emergency exit; but if they sign it as an emergency exit they have to keep it clear.
dosxuk
2 Jan 2011
Emergency exits can be taken out of use for being unserviceable. The fire and evacuation guidelines take this into account and capacity limits for licenced premises are also based on a proportion of exits being unavailable.
Even on the most disrupted wintery days I've never seen the concourse at Sheffield busy enough that I would have any concern about one exit route being closed for genuine reasons, especially since the next exit is only a few metres away.
