Hello everyone,
I'd be very grateful for any information people have on the following queries. Ideally pictures of some of the bogies highlighted in the text below. Those pics would be within a vehicle or even better removed from a vehicle for clarity etc. I doubt outside of RDDS anyone has drawings but if anyone does then that would be really really helpful. Or any dimensions of the wheelbase and bogie itself etc.
I'm researching the current DMU and EMU fleet and in particular the Class 150. I've been collating data from Platform 5 books, Ian Allen, Colin Marden, Brian Harescape and Angel and Eversholt websites. The following might be better presented as an Excel sheet (it is originally!) but here goes it as text...
I've collated the following - tried to make it as succinct as possible a summary but quite a bit of info so here goes
Class 150 uses BP38 and BT38
C153 P3-10 and BT38
C155 P3-10 and BT38
C156 P3-10 and BT38
C158 + C159 P4-4 and T4-4
First question: BP38 and BT38 are the same basic and related design?
Is the P3-10 completely different to the BP38? Naming convention change maybe but same design?
Is the P4-4 related to the BP38? T4-4 related to the BT38? At all??
-Anyone have pics of the BP38 and BT38 removed from a vehicle?-
I note the C150/158 and 159 are all BREL built (British Rail themselves then??).
C153/C155 are Leyand Bus and
C156 is Metro Cammell design and build
EMUs:
I note that the 507/508/313/314/315 are all related to the PEP 445 prototype and are family of related designs. All are listed as using the BX1 bogie. Data I've seen doesnt distinguish between powered or trailer bogies. All are just called BX1. So two versions with the same name? I also note this series of EMUs adopted driving motor at each end configurations (as an aside).
A BR research document states the BX1 as equal to the BT38. Different name for the same design in different EMU or DMU rolling stock then? Can one therefore assume that if the BT38 is related to the BP38 in general design and dimensions and since the BX1 is noted as the same as the BT38 then the BX1 is equally related to the BP38?
-Anyone have pics of the BX1 powered bogie and trailer bogie? Powered one is more interesting. Ideally removed from a vehicle. Or any other pics or drawings?-
The line in the BR doc is about a prototype lightweight bogie for the C154 prototype and simply states it is proposed as a "replacement to the current Class 154 bogie namely the BT38 (BX1)"
A paper written by one of the engineers who worked on the C210 DEMU prototype notes it used BP20 and BT13 bogies and that paper has the comment that "the BT13 is nearly identical to the BX1).
So BX1 = BT13 = BT38 then?? (and all related to BP38 as well then?)
Are all bogies of the 507/508/313/314/315 DM powered? All 4 axles are powered?
I note the Class 150 is based on the Mark III coach structure
and that there are a series of Mark III coach based EMUs too, namely the:
C455 - using BP27 and BT13
C456 using P7 and T3
C442 using P7 and T3
As above, are the BP27 and P7 and the BT13 and T3 the same design but a name change or completely different designs?
also
C317 uses BP20 and BT13
C318 uses BP20 and BT13
C319 uses P7-4 and T3-7
C320 uses P7-4 and T3-7
C321 uses P7-4 and T3-7
C322 uses P7-4 and T3-7
I also note that apart from the C456 the C455, C442, C317, C318, C319, C320, C321 and C322 all use motor trailers within the unit (just as aside point really).
In those mid-unit motor trailers are a both bogies powered? Are therefore all 4 axles in the motor trailer powered?
BP27 is different how to the BP20? Are these related to the P7 and P7-4 at all?
BT13 = T3 = T3-7 as well??
Also from above BR doc notes the BT13 = BX1 and another doc notes the BX1 = BT38 as well
I also have a note the bogies in the in the C317, C455 and C442 are larger than the usual "series 3" bogies. Not sure what series 3 refers to but a comment is that they are larger due to having headstocks with brake gear on.
I presume that applies to the whole Mk III structure based EMUs listed above
Is the wheelbase longer or is it the overall length due to the headstock with brake gear on. Is that just a bar mounted across the end of the bogie?
Anyone have any pics of the BP27, BP20, P7 and P7-4 removed from a vehicle per chance? Wondering what brake gear is mounted on this headstock exactly
Given all these relationships and that BP38 is related to BT38 = BX1 = BT13 that reason I'm asking all this is that therefore could a powered BX1/BP27/BP20 be installed in a C150 replacing the BP38
Are these all a related family of designs then?
Thanks!!!!
C153 P3-10 and BT38
C155 P3-10 and BT38
C156 P3-10 and BT38
EMUs:
also
Thanks!!!!
