Yes I realize you can't assume a structure will be fit for purpose and the structures would require remediation before use, but in the end of the day the vast majority of the large iron bridges on the old Waverley line in the Gala Water valley were refurbished and are used on the reopened line. I don't think it's unreasonable to assume that the Thistle Viaduct and the Kershope bridge could be reused as well as they're used today for farm vehicle access and they appear to be in reasonable condition.
Also, are you really suggesting £20M per mile for essentially a basic siding with a 25mph speed restriction, no loops other than a ground-frame operated run round loop at the railhead, no signalling or associated support infrastructure, and no stations? If the Borders line could be rebuilt as a fully signalled 90mph line speed railway in 2014 with a 1/3 of it double track and 10% of it on an entirely new alignment at £12 million per mile based on published costs (and yes I realise you dispute the official published figures but still...), I would have thought reinstating a basic low speed single line on an essentially unobstructed solum could be done for a fraction of that cost. You wouldn't need a gold-plated spec for a freight siding operating a handful of trains per week.
Yes, I’m seriously suggesting that, because I have been involved in building railways for most of my career, and have spent much of my life pouring through detailed costings of the same.
The cost of a new, double track railway to be built in future (and not in the past) is around £30m/mile, much, much more in some cases. Where does this cost go?
There’s a significant proportion of the cost that is incurred regardless of what the specification of the railway is. Consents. Land purchase. Clearing the route (de-vegetation, fencing, environmental mitigation, land remediation). Stakeholder management and communication. Utilities. And not least, in this case, assessing the integrity of the existing infrastructure.
Next, there’s another category of expenditure that is not directly proportional to route spec. Take track for example. By far the majority of costs of installing track are in the the costs of labour, plant, and the logistics of getting the materials there. There’s not really such a thing as ‘low spec’ new track. Sure you can buy second hand sleepers, that would save you about £15k a mile, and you might only put 200mm of ballast down rather than 300mm (although I wouldn’t recommend it there), that would save perhaps the same again. Thats it - everything else is the same. That’s set against total costs of new track of well over £1million per single track mile.
Civils is in the same category. The cost of installing a new bridge / culvert for a little used freight line isn’t much different to installing a new bridge /culvert on a new high frequency conventional passenger line. The civils works for this line would have to be to a higher spec than the existing Borders route, because it would see regular (albeit infrequent) heavy axle load traffic. Notably the existing Borders line doesn’t, which is one of the reasons why some of the existing structures could be retained. I’d be very surprised if structures that have laid dormant for more than half a century and carry the occasional tractor could accommodate 1000t freight trains with 20t axle loads several times a day with significant structural remediation.
Signalling is a fair point. Nevertheless, installing modern low spec signalling on a new railway is relatively cheap. The reason re signalling existing railways is so expensive is firstly that a significant part of the job is removing the old kit, secondly that the new kit has to interface with old kit either side, and thirdly that most of the work is done in 4 hour windows overnight, amd/ or in intense working periods at weekends and Bank Holidays, with extremely dire consequences if it goes wrong (and thus extra resources and contingency are planned). None of this applies to a new line. The costs of signalling the Borders line was relatively small.
Then on top of all of this, you would have hordes of people, most of whom who have never been to that part of the world, whinging that you were spending all the tmoney to open a freight only line, but that it wasn’t ‘future proofed’ to passenger standards.
Expensive business, building railways. Underestimate it at your peril!
