GE Signals
- Joined
- 18 Apr 2019
- Messages
- 1
Does anyone know how the key locks at Brundall LC worked with two key lock 'panels', one in the Signal Box and one in the Gate Hut? Normally only one key-lock 'panel' would be provided.
I worked on Brundall Box 1988/89. The box just used locking lever from what I recall which was no1 in the frame. The crossing keeper would take a key out of either gate once closed & locked across the road & insert them into the box in the hut & turn. This then allowed the signaller to return the lever to the frame & clear the signals.Does anyone know how the key locks at Brundall LC worked with two key lock 'panels', one in the Signal Box and one in the Gate Hut? Normally only one key-lock 'panel' would be provided.
Way back the signaller would operate the gates themselves early on Sunday mornings & occasionally if a night shift was added for engineering. It is far too busy at other times.I assume this arrangement is due to the signal box being close to the junction near the end of one platform while the level crossing lies between the two platforms?
