Bus replacement or diverted train?
kuepper
16 Jan 2017
I'm doing a return trip on 14th Feb Glossop to Preston with 1 change at Manchester Piccadilly (MAN) and I'd be returning on the 22.22 arriving MAN at 23.13 then 23.29 (the last train) to Glossop, all Northern services. On Trainline and Northern route planners there was a flag on the return journey "Rail replacement bus on some routes" which worried me. I looked on Northern's site at engineering works https://www.northernrailway.co.uk/west-engineering-early-2024. That seemed to suggest there was no replacement bus on any line I'd be on but that the train from Preston would be diverted a different route to MAN - but I've no idea if that means a later arrival or not. However when I looked at a return trip for MAN- Preston only the Trainline did not flag up "Rail replacement bus on some routes" as it had done when looking at Glossop to Preston return, so does that mean the MAN to Glossop leg is a bus replacement service but if it does why wouldn't that show up in Northern's engineering works list?
If not on here where is the best source of clear information on this - I've had problems with both Trainline and Northern before so don't trust them to give accurate information.
27 Jan 2008
Realtime Trains shows both journeys as WTT and normal routing
kuepper
16 Jan 2017
Thanks but who are Realtime Trains? I've never heard of them
23 Jan 2013
Eccles Signal Box
Wouldn't believe anything Trainline tells you. Recently had quite a few people insisting it's a replacement bus to their destination because "it says so on Trainline" even though you've told them multiple times what platform their train is on. Eventually they miss their train because they continue to believe Trainline over the actual staff. Also people who stand around looking for nonexistent trains such as from Warrington Bank Quay to Warrington Central, because Trainline has given them a time and neglected to mention that's the time to walk between the two.
YorkRailFan
6 Sep 2023
York
A site which uses signalling data to identify the routing and location of trains. It also shows what train you will be traveling on (ie set and class) when looking closer to the time.
30907
I can see that information only at the head of the column which refers to various trains over several hours. I suspect the flag-up is because there will be RRBs operating on the Bolton route which the trains normally serve.
The detail info for your journey on Northern's site (and TL), and the NRE site, has both legs shown as trains, which is the same as the detailed times provided by NR (which allow for the diversion BTW).
