Cable theft becoming a more common occurrence
AlastairFraser
12 Aug 2018
If. And they happened to be wearing something distinctive, and looked at the camera, etc etc. These people aren’t stupid. Well, most of them aren’t.
They're still stupid enough to try and move stolen metals in the first place.
Perhaps an alarm attached to the cable at regular intervals would help, power wouldn't be an issue! A simple radio transmitter attached broadcasting to a receiver in the nearest signal box would alert NR to an ongoing incident.
Or sturdy locks on the trough lids with keys held at the nearest pway base.
Bristol
And then techs would be forever chasing false alarms
Or forever testing and fixing broken transmitters
A big hammer will serve far better than any key.
The only true way to stop any form of theft is to prevent people making money from it. Realistically, that means hoping the price of metals falls wholesale.
Ultimately we probably just have to reduce the amount of cables on trackside, data cables are convertible to fibre optic, but powered equipment can not be.
If we could get ETCS with onboard train completeness we could delete the bulk of the trackside power cables.....
Bristol
Even ETCS with track circuits would help, as the bulk of the signalling data transmission is done over radio, and there's no signals to power so it'd be worthwhile to protect the remaining cables much more effectively.
Annetts key
13 Feb 2021
West is best
Four points:
  • ”Tail” cables (relatively short cables from equipment cupboard/cubicle to nearby signalling equipment such as colour light signals, track circuits, AWS, TPWS, ATP, point operating equipment etc.) are normally not targeted or damaged by cable thieves. Sometimes vandals pull any slack on to the rails for trains to cut them, but this does not occur very often. Cable thieves normally go after the much longer “lineside” cables.
  • Data communications cables already don’t have much value, as the amount of copper in them is not very large.
  • Some of the less intelligent thieves cut many of the cables to see which have large amounts of copper, and in the process cut the fibre optic cables as well…
  • Everything signalling wise needs a ‘guaranteed’ power supply, so you still need a power distribution network of cables. Especially for power hungry items like point operating equipment and telecommunications/GSM-R (railway mobile communication system) sites that carry the ETCS signals. If train detection uses axle counters, the buildings that house the Axle Counter Evaluator (ACE) equipment needs power as well.
So less cables may not automatically reduce the problem, instead it’s likely that the thieves will simply move along the railway until they find some cables to attack.
Bristol
This will always be a problem
Although with much less data cables to carry and theoretically fewer items of signalling to install it is still less cabling.
Less cables is less opportunity though, and if the thieves now have to walk 2 or 3 times as far to get the cables they're going to be less interested in it as a target.
AlastairFraser
12 Aug 2018
That's never going to happen. We need better anti theft measures.
AlastairFraser
12 Aug 2018
They're not going to be worth the money, realistically.
Well, less cabling would help, to be fair. And anchoring the remaining fixed infrastructure on a potential ETCS style system more firmly into the formation would help.
Bristol
It really won't. A good pair of cable clippers or lock cutters would make short work of any anchor. People get through bike locks in seconds nowadays, how thick are your proposed anchors?
Hellzapoppin
16 Jan 2016
Some cables are anchored but that's done to prevent vandals dragging the cable across the track. Buried duct routes, good idea but won't work in the railway environment, in the vast majority of places there isn't the space to install routes and what if you need to move the cables to facilitate engr works. Lockable lids, well they are available but big hammer or a disc cutter straight through the lids,cables and troughs is really easily. Cable monitoring, already done in some areas but by the time someone gets to site the cables have been cut, shoved in the back of a van and gone. You wouldn't believe the lengths these people go to to get the copper.
With ETCS with onboard train completeless check the amount of powered trackside equipment would fall precipitously.
You might go many miles between point machines, and axle counters probably wouldn't be much more common. (As an example, in the 15 miles between Grantham [the Nottingham line junction] and Newark there are something like two sections that would require power....)
And you can put rather more fencing around a point site like an ETCS communications mast, or just put it on top of a building or something.......
AlastairFraser
12 Aug 2018
The thickness of a rail, at the very least. I wasn't talking of a cable-based lock!
Oh I understand it's valuable and that motivates thieves to go lengths accessing it, but there must be a better way to protect it.
I think the best medium term suggestion to be honest would be HSTEd's suggestion of redesigned aluminum steel cabling, to disincentivise it.
That gives about 30 seconds more notice. But it is done in certain circumstances.
Indeed. ETCS is a big help here.
AlastairFraser
12 Aug 2018
30 seconds may be worth it if BTP/NR could start sealing off the area in that time. Or activate CCTV so the cable thieves' location is known.
Bristol
How many people do you think are working to prevent cable theft? 30 seconds will make naff all difference.
skyhigh
14 Sep 2014
"sealing off the area"? There isn't a squad of tens of people and a helicopter that can be scrambled at seconds notice to stop anyone leaving any area. I'm sorry but it's really not practical.
Depending on location, it could take BTP over 30 mins to get there. 30 less seconds won't change a thing.
The honest truth really is that there isn't that much more that can be realistically done to reduce cable theft.
AlastairFraser
12 Aug 2018
I was thinking of more an urban location near London where it would have more impact on services if cable was stolen.
RSARNA
19 Feb 2021
South Africa
I live in South Africa and the people here are the experts not only railways but roads as well the cables were put above ground from lamppost to lamppost so
From our town to the city 30k,s they fixed a rope and a within a few weeks pulled all the poles down and stole the wire. One guy they caught was steeling the wire
out of a point motor in the City main rail line.
al78
7 Jan 2013
Only the lowest end ones. Good luck in getting through these in seconds.
Bristol
How much is reasonable for NR to spend on a fixing, given there's something like 16,000 route KM of railway in the country and a fixing is proposed every 5m? That's 200 fixings per KM of cable, remember.
InOban
12 Mar 2017
Never mind South Africa, do they have the same problem on the Continent? I understood that the problem was meant to have been addressed by the licensing of scrap dealers and a ban on cash deals, but the thieves soon found a way round this.
Bristol
I'm not sure if it's to the same extent, but I've certainly seen reports of delays due to cable theft this side of the channel.
That is done.
Not much cable theft on railways in urban locations - too many people / CCTV / ANPR around.
that certainly has reduced the problem. But yes there is a similar problem on the continent.
Gostav
14 May 2016
As far as I know, in Japan, if a thief dares to steal railway cables especially on mainline who will commit not only crime of theft but also the crime of destroying the transportation system what is a felony that almost reaching the level of terrorist attacks and treason, it's almost easy to get a sentence of more than two years. I believe that in so does in China.
There have been a few cable thieves here who were charged with the offence of Endangering the Safety of Rail users, and that carries a maximum sentence of an unlimited fine / life imprisonment.
43066
24 Nov 2019
I believe there have also been a few over the years who have paid the ultimate price by getting themselves juiced!
