Calder Valley line improvement works
superkev
1 Mar 2015
west yorkshire
Pics from Sowerby Bridge bus substitution day today (mon) of departure screen and new base for platform 1 ticket machine.
No progress on the short platform extensions since last pi kcs despite the opportunity of having no PSX_20181022_163725.jpg 20181022_151352.jpg rains.
K
61653 HTAFC
18 Dec 2012
Another planet...
Seems like the left hand doesn't know what the right hand is doing... surely the signalling blockade was the perfect opportunity to get the platform extensions well on their way to completion.
Anyone got Anneka Rice's phone number? She'd only need a weekend!
Sowerbylad
22 Oct 2018
Just seen possibly the first movement through sowerby bridge station since last Friday. What looked like a 2 car heading east at speed.
Geeves
6 Jan 2009
Rochdale
There is a 5Z10 on its way through Brighouse.
There is also a 1Q14 at Huddersfield presumably heading that way too. Unsure how the testing went as someone stole the cables at Morley earlier. Hopefully the new cables go along both the Morley route and the Bradford ways for some kind of failsafe in the future.
9 Jan 2007
Neither 1Q14 or the return, 1Q15, are going near the Calder Valley this evening.
1Q14 is going directly to Manchester Piccadilly from Huddersfield and the return, 1Q15, is booked to Derby RTC via Huddersfield, Leeds, Swinton & Chesterfield.
rich-leeds
26 Jan 2017
I saw 150133 (old Northern Rail livery) head out of Bradford Interchange towards New Pudsey at around 1745 today. Could have been the same unit if this is scooting around the area under possession? I took this to be either part of the commissioning of the new signalling, or driver training on the new bits of infrastructure (or both?). Appeared to have a cab full of people.
rich-leeds
26 Jan 2017
I took a nose around Bradford earlier to see if there was anything interesting going on. First picture is of the new Ripley Junction, south of Mill Lane Junction, as seen looking north from the Ripley Street overbridge. It was installed in summer, but comes into use with the resignalling. It was October 2008 when the layout around Mill Lane junction was last expanded - so exactly ten years ago. Pic beneath that shows the revised layout in Bradford Interchange station throat as seen from Caledonia Street, which also comes into full use tomorrow.
New 'MU' speeds have been introduced alongside the resignalling. In the Bradford / Low Moor area the basic line speed remains 55, but just south of Low Moor station heading 'up' toward Halifax the MU speed is 80, and at the northern portal of Bowling Tunnel it is posted as MU 70. These seem like decent increases. Not much help for TPE traffic on diversion though - I assume 185s are still not able to take advantage?
takno
I've updated Traksy with a very rough attempt at a diagram for the area at https://traksy.uk/live/M+22+RTHP+18. Until there's a bit more data through then the signal positions around Bradford are total guesswork, as is the location of Low Moor. Locations around Mytholmroyd and Sowerby Bridge could also be sketchy.
rich-leeds
26 Jan 2017
Looking good. That's a big increase in the number of signal locations between Halifax and Bradford Interchange. If it's of any help, I can tell you that new signal MM6237 is located around 350 m north of the platform end of Low Moor station on the down line.
takno
Think it's pretty much there now. There's a *lot* more signals in the Hebden Bridge, Milner Royd and Halifax areas, as you would expect. The Mill Lane area seems fairly similar - might have been a like-for-like changeover
Sowerbylad
22 Oct 2018
Working well, thanks.
bengley
18 May 2008
185s can do MU speeds. They can't do SP (sprinter) speeds.
rich-leeds
26 Jan 2017
You've prompted me to check - there's a 'national exemption' on class 185s that prevents them from taking advantage of 'MU' or 'DMU' speed differentials. I've started a new thread on speed differentials here, as I was quite interested to revisit the source info.
I know there's much in the way of route clearance hurdles for Mk5s and the 802s still to overcome on the Calder Valley, but at present looks like only the 802s in TPE's emerging fleet have any prospect of taking advantage of the higher speed restrictions in the case of future diversions. There are also some pretty decent MU differentials on the Calder Valley line west of the Pennines between Rochdale and Newton Heath (up to 90mph in places over a base restriction of generally 70mph) that were delivered as part of the first phase of Calder Valley upgrade work on the LNW side a couple of years ago.
142Pilot
24 Sep 2018
158's are good for 90. However if coming out of manchester means that you are getting the curly finger as the max line speed is 80.
It's 90 from Castleton Junction to Moston.
rich-leeds
26 Jan 2017
What's the line speed milner royd to hebden bridge please?
On the up: 60 | MU80 from Milner Royd junction to Mytholmroyd, then 60 | MU70 from Mytholmroyd to (and beyond) Hebden Bridge.
On the down: 60 | MU75 all the way from Hebden Bridge to Milner Royd.
The speed restriction through Milner Royd junction on the movement from / to Halifax is 40 on the up and 40 | MU50 on the down.
Calderfornian
17 Jan 2018
I’m on the 05:47 Hebden to Leeds this morning and just saw the most bonkers stock movement. ECS arrived into Manchester bound platform (1). Reserved out across the crossing to the Leeds line. Reversed back into the Leeds platform (2) to await departure. This train and the later GCR stock departure to Leeds were always the two short services that went from the ‘wrong’ platform. Weird thing is whilst the Manchester bound line was freed up by the move, it was unused.
chrissawer
6 Nov 2013
This is resulting in a lot more detailed information on RTT for trains running down the valley, which is a nice bonus. Previously there was nothing between Milner Royd and Hebden Bridge.
crosscity
5 Dec 2011
In the two weeks prior to the closure of Hebden Bridge Signalbox the crossover was not used and the stock went up to Hall Royd Jct to reverse. Indeed the last movement at HB Signalbox was the ECS from the Leeds terminator, which went up to Hall Royd Jct and came back a few minutes later.
The movement might be bonkers from an operational point of view, but not from a customer service one. Why make eastbound passengers walk to the westbound platform?
Bungle965
Buses & Coaches
2 Jul 2014
Blackley and Broughton/ Walsall South
It is actually signposted at the station that some early morning services depart from the Manchester bound platform!
Sam
geoffk
4 Aug 2010
Rode from Walsden to Bradford and back today. There had been disruption from 0915 onwards, caused by a track machine or similar at or near Greetland Junction. Anyone know what happened?
The new signals have numberplates prefixed HG between Hebden Bridge and Milner Royd (also the signals approaching MRJ from the east), MM between MRJ and Bradford and DH on the bank down from Dryclough Junction. I'm guessing that these initials stand for "Hebden Bridge to Greetland", "Milner Royd to Mill Lane" and "Dryclough to Heaton Lodge"
The journey between Halifax and Bradford was noticeably quicker than before, with trains now covering this stretch in nine minutes. It's now 20p for a pee at Bradford Interchange!
Platform extensions at Sowerby Bridge are almost complete - on the down line it's a reinstatement of part of the disused platform. The same applies at Todmorden on the down line. I assume these extensions, most of which are very short, are to allow class 195 trains to call when coupled in multiple (i.e. four cars), as the driving cars are 24m long.
superkev
1 Mar 2015
west yorkshire
Today's update from the 12week Sowerby bridge short platform extensions and new platform 1 ticket machine and mystery machine. Apparently shutting line Sunday to do more. Words fail me. Glad I'm not paying for it.
K
Halifaxlad
5 Apr 2018
The White Rose County
Just next door, it looks like Mytholmroyd is also getting another Ticket Machine upon the Manchester bound platform!
Does anybody know if Brighouse will be getting a single Ticket Machine and why it doesn't already have one?
Bungle965
Buses & Coaches
2 Jul 2014
Brighouse will be getting a ticket machine. As for the reason it has not got one yet, it is most likely on the list but that the engineers have just not got round to that station yet.
Sam
superkev
1 Mar 2015
west yorkshire
Today's (fri) update from Sowerby Bridge. Someone actually working on the 13weeks so far platform extensions pic attached.
No more progress on Platform 1 ticket machine and adjacent mystery machine.
Friends of Sowerby Bridge station have again won the platinum award with the station gardens pic attached.
