miklcct
For example, can a Bakerloo line train run into the Jubilee line via Baker Street so Stanmore in passenger service, if there is a disruption on either line?
There's no way that they could divert in service, many safety rules would be broken by doing so.For example, can a Bakerloo line train run into the Jubilee line via Baker Street so Stanmore in passenger service, if there is a disruption on either line?
This is 'easily' (note inverted commas) solvable by swapping drivers at the appropriate point. A crew change en route is not a new concept. That doesn't change the other points, of course.) Drivers don’t generally have knowledge over other lines, so even if the previous two issues were reconciled, the answer is still no. Indeed, at times LU seems to have enough trouble with their drivers knowing their own lines properly, let alone other lines!
All 1972 Stock originally delivered to the Northern, transferred to Bakerloo from JubileeThe 1972 stock originally ran on the Jubilee line, so from a stock point of view, it's almost certain possible.
So the next question is are drivers trained to drive stock which doesn't normally operate from their depot/on their line... I think that l already know the answer....This is 'easily' (note inverted commas) solvable by swapping drivers at the appropriate point. A crew change en route is not a new concept. That doesn't change the other points, of course.
How about a Bakerloo line running onto the Jubilee at Baker Street to run to Stratford.... I'm sure that the platform edge doors won't be an issue, lol.....For example, can a Bakerloo line train run into the Jubilee line via Baker Street so Stanmore in passenger service, if there is a disruption on either line?
Piccadilly line has ran to Ealing Broadway in passenger service during Christmas closures on the district line, this was done hy having a piccadilly line driver and a district line pilot.
Interestingly though, once this occurs there will still be a mix of stock types on the Piccadilly (formerly District) platforms at Ealing Broadway, as it will still be part of the route for many of the District line S7s returning to Ealing Common Depot, though presumably by then not in passenger service...In the case of Piccadilly to Ealing Broadway the medium term aim was for the Piccadilly to replace the District service there anyway. Altering the platform heights might even be required to meet modern standards if both types of stock were no longer in normal use.
Won’t that depend on any track changes at Ealing Common depot approaches though. But probably drifting off topic, I think potential depot aspects came up in a previous thread.Interestingly though, once this occurs there will still be a mix of stock types on the Piccadilly (formerly District) platforms at Ealing Broadway, as it will still be part of the route for many of the District line S7s returning to Ealing Common Depot, though presumably by then not in passenger service...
Have the glass tubes containing silver paint that set the signals to red if a Met / District train heads for the Jubilee / Piccadilly tunnels been removed?Until very recently, the Piccadilly line was able to operate over the District 'local' lines between Hammersmith and Acton Town (and indeed was scheduled to operate a small number of trips). Piccadilly line trains even served the District line stations such as Ravenscourt Park during some disruptions. However, the re-signalling of the SSR has meant that this flexibility has had to be lost and the crossovers between Barons Court and Hammersmith that facilitated this have now been plain lined.
Until the early 2000s a similar situation existed on the Jubilee line between Finchley Road and Wembley Park, where a few late evening Metropolitan line trains used now removed crossovers at Finchley Road and operated across the Jubilee line tracks and served the Jubilee line stations.
Early morning Piccadilly trains did reverse at West Kensington for crew refresher purposes but this was withdrawn many years ago and 1973 Stock are no longer permitted without modification onto 750v DC beyond Barons Court.I'm sure I've seen a photo somewhere of a Piccadilly line train at West Kensington and then Earl's Court district but maybe I just dreamt that??
Not quite related but interesting I think:
Met line trains (at least the A stock) could terminate at Rayners Lane although the siding is used almost exclusively for Piccadilly line trains.
The surface stock detection still exists at Hounslow and Barons Court because the sets of points enabling trains to cross over from the local to the fast at Acton Town still exist, and will remain, in situ as Piccadilly line trains still require access to the local lines at Acton Town.Have the glass tubes containing silver paint that set the signals to red if a Met / District train heads for the Jubilee / Piccadilly tunnels been removed?
This is all fascinating stuff. Sorry for the ignorant question, but how exactly does silver paint set a signal to red?Have the glass tubes containing silver paint that set the signals to red if a Met / District train heads for the Jubilee / Piccadilly tunnels been removed?
Traditionally the tubes were filled with mercury, when this became a banned substance the tubes were coated on the inside with conductive silver paint. Breaking the tubes, breaks the circuit.This is all fascinating stuff. Sorry for the ignorant question, but how exactly does silver paint set a signal to red?
The existing single-track connection between the Northern and Piccadilly lines isn't suitable for running a service, but plans to dig new crossover tunnels in response to a disaster were probably sane.Wasn't the cold war post attack plan to consolidate some lines together to provide a service that could use lesser damaged infrastructure eg combining the Northern and piccadilly line to provide a service.
Does the 1960 stock Track Recording Train still go on the Central Line these days, as i know that there is videos of 1992 stock doing track inspections as the TRT contains a 1973 carriage so they must be able to use the Central LineWould the longer carriage trains (73, 83 before being scrapped, 95 and 96) fit on the Bakerloo and Central lines, with their tight curves? Or is the only issue unacceptable gaps between the doors and platform at stations like Bank?
The TRV will still do the Central Line, there's no ATMS fitted to the 1992TS so there is a need to carry out the more regular inspection routines.Does the 1960 stock Track Recording Train still go on the Central Line these days, as i know that there is videos of 1992 stock doing track inspections as the TRT contains a 1973 carriage so they must be able to use the Central Line
The tunnel rings needed to be shaved at South Kensington when the 1973 stock was introduced on the Piccadilly Line, so it seems unlikely they would fit other lines without some shaving, if at all.Would the longer carriage trains (73, 83 before being scrapped, 95 and 96) fit on the Bakerloo and Central lines, with their tight curves? Or is the only issue unacceptable gaps between the doors and platform at stations like Bank?
