Cardiff Central - London Paddington record attempt
Discussion in 'Allocations, Diagrams & Timetables' started by bignosemac, 26 Oct 2011.
Thread Status:
  1. bignosemac
    bignosemac Established Member
    4,985
    12 Oct 2009
    Rail Forums
  3. The Planner
    The Planner Established Member
    9,683
    1Z37, currently at Severn Tunnel Jn running 1 early. If it doesn't use the allowances in its schedule then it should do it in 94 minutes.
    Interesting to see what the claimed time is, as TRUST shows a journey time of 96 minutes. 1220 off Cardiff, 1 early and 1356 arrival into Paddington, 2 early.
  4. bignosemac
    4,985
    12 Oct 2009
    Shortened HST set apparently. 2+5.
    Just like the record run from Plymouth last October, which also used a shortened set. That one beat the previous record by 17 minutes.
  5. The Planner
    9,683
    So all a bit pointless and doesn't really prove anything, a 2+5 should easily beat 2+8 times.
  6. bignosemac
    4,985
    12 Oct 2009
    I think the point is to show the politicos and business community in South Wales the merits of taking the train. That was the reasoning behind the run from Plymouth. This run also saw dignitaries and business folk being invited along.
  7. notadriver
    notadriver Established Member
    3,284
    1 Oct 2010
    If he can keep it right at the limit - 127 mph on the high speed sections it might be interesting!
  8. bignosemac
    4,985
    12 Oct 2009
    Left Cardiff Central at 1220. Arrived London Paddington at 1356. 96 minutes.
    So the record was broken, at least according to TRUST. But only just.
  9. route:oxford
    route:oxford Established Member
    4,855
    1 Nov 2008
    So a new record set.
    So, if this was undertaken by an alternative 125mph Diesel stock, ie 180,220,221 or 222. (Assume the 180 behaved all the way).
    Would the improved acceleration have helped cut the time?
    And by how much?
  10. eastwestdivide
    eastwestdivide Established Member
    1,833
    17 Aug 2009
    If it was a reduced-length HST set, would the acceleration have been much different anyway? Also, there can't be too many places on that route where it would need to accelerate, most of the run just being sustained high speed.
    I suppose if it was GW putting on the show, it makes more sense for them to use one of their own trains instead of the hassle of arranging something different. Would be an interesting comparison though.
  11. The Planner
    9,683
    Coming round the bend at Parkway is about the biggest step up. Swindon might be a 40mph step as it is 80 through the station ?? The rest are marginal.
  12. route:oxford
    4,855
    1 Nov 2008
    Severn Tunnel?
  13. The Planner
    9,683
    75 and it is only 90 either side if I recall.
  14. PaulHarding150
    PaulHarding150 Member
    742
    13 Feb 2011
    Cardiff
  15. TGVDUDE
    TGVDUDE Member
    1,041
    1 Jan 2009
    Cheltenham
    Bristol Parkway eastbound is 125 straight after the platform I believe
  16. The Planner
    9,683
    Have they upped it now?? I thought it was Westerleigh before you got flat out.
  17. LNW-GW Joint
    LNW-GW Joint Veteran Member
    13,985
    The report I saw on BBC Wales news was a travesty.
    The gist of it was £1B spend will give you 17 minutes saving Cardiff-London.
    The only railway "expert" (an academic I think) pointed out it was 2x17 minutes for a round trip. Big deal.
    Then all the (Cardiff) people-in-the-street interviewed said that if that was all you got for £1B they would prefer it spent on something more useful (hospitals, schools etc).
    Then the obligatory Swansea resident (a business woman) said if the wires stopped at Cardiff she would be no better off anyway, so why bother?
    Don't you despair at the newshounds (who no doubt had a good free lunch courtesy of FGW).
Thread Status:
Share This Page
