Central line train destination
Busman
4 Mar 2017
Following some operational issues today with the Central line - and let's be honest, when isn't there - some trains were being terminated at Woodford to platform 1 and then heading back to London which was an absolute result for me because it guaranteed my bum would get a seat. However, this thread isn't about getting a seat on a seat devoid of any cushion, no, when the train was pulling into the platform, from a distance it looked like 'Woodford' which is fair enough but as it got closer, it said 'Waterloo'.
Why would a CL train have Waterloo as a pre-programmed destination when it doesn't touch south of the river? Is it because the trains are related and when they were made they had destinations set across both lines? If so, why did it say Waterloo? A bug in the system? A driver error? Sadly, you won't see Woodford on the Waterloo & City line as destination screens are now static.
So many questions .....
Very odd but fascinating at the same time.
Anyway, does anyone know? :idea:
Dstock7080
17 Feb 2010
West London
all 1992 Stock have the same destination code software; so Central trains can show 'Waterloo' and 'Bank'.
Ongar is also still available.
Busman
4 Mar 2017
Indeed, you still see Ongar as a destination when some trains are parked up in sidings and depots.
Why do they still appear though, is a glitch with the system or do drivers do it for what 'could have been'?
MaidaVale
18 Jun 2021
SW London / Berkshire
Some T/Operators still choose to set Ongar, Bank or Waterloo if in a siding or depot, providing they know the right codes for the destination system, which are not displayed on the regular list of codes found either physically on the trains or within the duty books/stock handbook. They should not be used in service, so I assume what you saw was a wrong code inputted by the driver.
The current destination system, despite having newer physical displays, still runs off of the same system as it did from new, hence the presence of Ongar (Only one 92 ever made it up there on test from my knowledge). I'm unsure as to whether or not the CLIP Project (ongoing refurbishments) will see the removal of these destinations with the new system although I assume this to be the case. Bank and Waterloo are likely only on there for compatibility reasons with the W&C stock from new.
MaidaVale
18 Jun 2021
I’ve got a photo of that somewhere
Not my photos credit to Paul Smith on Flickr. Shows 91035 and 91033 at both Ongar and Blake Hall. You can also see the original destination/number displays clearly in these photos which may help to explain as to why the destinations are still on the system.
bakerstreet
29 Nov 2009
Thanks for posting those!
DerekC
26 Oct 2015
Hampshire (nearly a Hog)
DLR cleaners used to set "Lewisham" as the destination when they had cleaned a unit, long before the extension was even started. Maybe the LU cleaners do the same with Ongar?
Busman
4 Mar 2017
Absolutely superb. If only it still ran to this day.
321over360
17 Jul 2015
Train destinations on the 1992 stock can be funny, last night i got a train going East at Stratford (it was a Hainault v Newbury Park service) and on the front it showed White City, when I got in, it said "This is a Central Line train to Hainault v Newbury Park".
Even more bizarre a week or so ago, I was at newbury park and just missed a train but i heard it announce "this is a waterloo & city line train to" by which time the doors had closed.
I have also seen a train with Hainault v Newbury Park on the front but Loughton on the back.
Another anomaly was a Hainault train, but had Epping on the Destination blind, when it was at Wanstead, it announced "This is Wanstead, This is a Central Line train to Epping". I was hoping when i was at Redbridge i could video it, but the driver must have fixed it cos it was announcing correctly as a Hainault v Newbury Park service.
Busman
4 Mar 2017
Not as odd as the observations above but another one I find is strange is once the train passes Newbury Park, the announcements still say 'Hainault via Newbury Park' at Barkingside and Fairlop.
And one more ... at Hainault, even when trains when when around the loop to London in both directions, why don't or/ didn't the announcements operate as 'Ealing Broadway via Newbury Park' or 'West Ruislip via Woodford'.
357
12 Nov 2018
The reason is because the system is from the late 80s/early 90s and can't auto update a destination mid route.
For those who are interested, manually triggered DVA code 36 is "thank you for traveling on the Waterloo and City line".
Destination 90 is Bank, 95 is Waterloo and 99 is Ongar.
Assuming the above hasn't changed at any point in the last 15 years!
Station announcements for Bank and Waterloo are also on there but I've forgotten the numbers.
MaidaVale
18 Jun 2021
Interestingly the Dot Matrix displays on the platforms still display "Hainault via Newbury Park" at Newbury Park, Fairlop and Barkingside by default, although the signaller can change these through the signalling system manually if they want to, It's just obviously not done as this would have to be repeated for every single train.
RacsoMoquette
24 Nov 2023
South Cambridgeshire
Just out of curiosity, did the Central Line 1992TS carry card destination displays akin to the units of the Waterloo and City Line? The latter units only had them during the best part of 1996 due to persistent reliability problems with the system, often involving poor visibility and flickering text being an issue.
Also when did the original style destination and train set number displays get upgraded to their Preasant appearance? As if I remember correctly, the original font was comparable to the style on Class 465 Networker units. But why was it changed? Seeing as the updated displays which still exist today ( Pre CLIPED units at least) has always been poor quality due to flickering at quite a frequent rate and sometimes certain letters seem completely deformed!
Dstock7080
17 Feb 2010
West London
Yes the original destination displays were LCD and quickly deteriorated to the point that card destinations were used instead.
The displays were changed to dot-matrix units that are now being replaced again under CLIP.
RacsoMoquette
24 Nov 2023
Thankyou for that valuable information, if that was so, why did the LCD units on the 1995 and 1996TS stand the test of time and lasted until the units respective mid life referbishments. Were they more robust and superior quality to the similar however less advanced units on the 1992TS?
ijmad
7 Jan 2016
For the 1992TS actually on the W&C, the displays were replaced during the 2006 refurbishment with fixed signs saying 'Bank' on on end and 'Waterloo' on the other as the trains only go to these two stations and are never turned.
Sad Sprinter
5 Jun 2017
Way on down South London town
They really were the best looking tube trains ever.
When they were ordered, was it presumed Ongar would become a regular destination hence the inclusion of the name in the electronic system?
MaidaVale
18 Jun 2021
It appears an Easter Egg has been added to the 92s updated PIS that includes an Ongar announcement (I assume when the Ongar destination is set)
Not my video
southern442
20 May 2013
I'd imagine that's maybe just the PA test announcement to check if the system is working? It's a nice touch.
ballas
7 May 2014
Not my video
I hear that this specific announcement is being removed from the system before trains enter passenger service... besides, whoever created this message missed the not insignificant fact that the line to Ongar closed in September, not March!
RacsoMoquette
24 Nov 2023
I highly suspect that the Ongar closure announcement will probably be hardly ever initiated, as it does appear to be a bit of an oddity compared to the rest of the Manuel announcements. However on the other hand it gives customers a brief insight in to the recent history of the line.
southern442
20 May 2013
I am almost certain it is not intended for passengers to ever hear, probably more something to check the PA system is working.
bluegoblin7
10 May 2011
JB/JP/JW
As already mentioned, the intention is that it will be removed before the trains enter full service. It isn't uncommon for test messages to be added whilst the final specification of the 'proper' messages is still being finalised.
Given that (again, as mentioned) it's factually inaccurate that's probably for the best anyway.
D7666
12 Aug 2013
What you mean us <( engineers add unusual test messages to systems ???? :lol:
Test messages with unusual content often draw feedback - then we know these things work; if we just put "testing testing testing 1 2 3 4 5" would anyone take any notice ?
BTW, before anyone asks, I am not guilty of Ongar, nor indeed of any audible or visual message anywhere. Well not currently anyway ;)
