Failed Unit
Just building onto this thread,
Since the arrival of Thameslink / EL and the ability to travel directly to many more destinations, some interesting situations have arisen.I was just wondering if the only way is to exit the ticket barriers and come back in?
For example you have a tickets from say Stevenage - London Terminals, today you want to travel to London Bridge. Before Thameslink offered the direct service you would level with your season ticket at Kings Cross, walk over the street and then tap in using your contactless card at St Pancras. Now the train is direct you still need to leave the station to tap in / out.
This is probably not a new issue, changing at Farringdon, the NR ticket isn‘t valid to get there if you are charging onto the tube / EL.
Just wondering what is the best process to ensure that you don’t needlessly need to leave the train or your are not paying for the same part of the journey twice (such as tapping at Finsbury Park before the London Terminal)
Changing from TL to EL at Farringdon - tap..?
So I went from St Pancras to Stratford via Thameslink and Elizabeth Line, changing between the two at Farringdon. There’s an oyster reader there that says to touch if changing between national rail and EL, which I was, so I did. The reader said “Exit” - so what happens when I now touch out at...
www.railforums.co.uk
