Charter Trains to Matlock and Rowsley
Llandudno
25 Dec 2014
Is it operationally possible to operate charter trains to Matlock and then onto Peak Rail at Rowsley within the constraints of the existing signalling system and hourly EMR service on the Matlock branch?
If so, when is the last time it happened and are there any plans for future charter trains to Matlock or Rowsley?
DarloRich
Fenny Stratford
Is the NR > Peak Rail connection available? last time i was there PR trains were not running into the main station for some reason.
Chris125
12 Nov 2009
Charters can - and occasionally have - run through to Matlock and Peak Rail since the line was upgraded, about a decade ago I think?
pdeaves
14 Sep 2014
Gateway to the South West
I believe it is. I think the problem is no run-round facility at Matlock (main line), so popular days where they want a steam engine they can't run through.
dggar
16 Apr 2011
Didn't they top and tail their trains into Matlock, pre lockdown.
12LDA28C
14 Oct 2022
The back of beyond
A problem easily solved by top-and-tailing which is the usual method of operation in these situations. The steam loco on one end and usually a diesel on the other, on charters at least.
LowLevel
26 Oct 2013
The reason they stopped using Matlock station for Peak Rail was the economics of using 2 locos - they've now rigged up a coach to use for propelling so hope to return there.
As for running off the NR branch, yes it's possible, though only late at night or on Sundays owing to timetable constraints. The most regular use is the railhead treatment train which goes into the loop there to let the last passenger service run.
plugwash
29 May 2015
IIRC peak rail normally run into matlock top and tail with one diesel and one steam loco but for a couple of months in the winter they run to riverside because that has a run-round look and thus only requires one loco.
petwall
6 Mar 2011
Basically correct: however services into Matlock have resumed over the half term holiday and will be operating using the following method tomorrow 22nd
The train is propelled back to Riverside where the locomotive runs round before heading back to Rowsley.
This method of working was first used on December 27th using 5553 and on the 15th, 18th, & 19th of this month using Eustace Forth
