Elecman
Can anyone come up with cheaper fares for 3 day trips from Newport to Paddington leaving on the 05.20 on Monday,Wednesday and Friday for the next 2 weeks?
These "also valid between" times capture the train in question, as it calls exactly at the listed stations, with departure times 03:46, 03:58, 04:05, 04:27, 05:07, 05:25, respectively. This train further calls at Bristol Parkway, Swindon (Wilts), Didcot Parkway and Reading before terminating at Paddington, and it's a GWR train, so none of the additional restrictions apply:Restriction code YV said:Outward Travel: Not valid for travel on trains timed to depart earlier than shown from the following stations:
- 08:30 (also valid between 02:00 and 04:30) from Swansea;
- 08:40 (also valid between 02:00 and 04:30) from Neath;
- 08:50 (also valid between 02:00 and 05:00) from Port Talbot Parkway;
- 09:10 (also valid between 02:00 and 04:45) from Bridgend;
- 09:50 (also valid between 02:00 and 05:30) from Cardiff Central;
- 10:00 (also valid between 02:00 and 05:45) from Newport (South Wales).
- Restriction code WO applies to all journeys via Newbury or Didcot Parkway, not passing through Reading.
- Restriction code Q8 applies to all journeys via Fareham / Southampton / Salisbury.
- Restriction codes CI / CJ apply to all journeys via London St Pancras International.
- For travel on CrossCountry please use 2V.
To return in between, firstly the Off-Peak Single (£65.20, for a total of £112.60) is valid on 15:18, 15:48, 16:18 and then 18:48. Note that journey planners also offer the Off-Peak Return (£109.80) for going out on the 05:25 and returning on these trains, even though strictly speaking its restriction code WV has a similar list of "Not valid for travel on trains timed to depart after 04:29 and before the times shown from the following stations" which the train satisfies at Newport 05:25, which is what electronic journey planners check, but fails at Bristol Parkway (05:54 is not within "(also valid between 02:00 and 05:30)") and Didcot Parkway (06:36 is before "09:54 from Didcot Parkway"), which the electronic journey planners don't check, so if you buy the Off-Peak Return then make sure you get it with an itinerary that clearly states the 05:25 departure as evidence of its validity.Restriction code YV said:Return Travel: Not valid on trains timed to depart:
Not valid on trains timed to arrive:
- London Paddington after 04:29 and before 10:10 and after 15:01 and before 19:00;
- Reading after 04:29 and before 10:30 and after 15:30 and before 19:00;
- London Waterloo after 04:29 and before 08:15 and after 15:59 and before 19:01.
- Salisbury before 09:30 and after 17:40 and before 19:01.
What time are you coming back each day?Can anyone come up with cheaper fares for 3 day trips from Newport to Paddington leaving on the 05.20 on Monday,Wednesday and Friday for the next 2 weeks?
Yes it is intentional; it is a longstanding principle that this particular train allows the use of such tickets.Both National Rail Enquiries and Trainsplit claim that the 05:25 departure from Newport (South Wales), arriving Paddington 07:16, can be travelled on with Super Off-Peak tickets (Single £47.40, Return £82.30). I don't know if this is intentional or not, but here's what their restriction code YV states:....
