Does national net zero require zero emissions of trains?ensuring that our rail network will have failed to play it's part in reaching net-zero (with significant sections still remaining unelectrified)
No,Does national net zero require zero emissions of trains?
In a decarbonised economy you won't be able to use solar panels to gain offsets, because decarbonised electricity production will mean that no carbon saved.No,
It is a net sum, so if have something else eg solar panels on depot roof feeding electricity into grid because make more than you use, then they are offset.
Not technically, because you could balance out remaining railway emissions with negative emissions / carbon dioxide removal elsewhere. However, in practice the likely answer is yes, because:Does national net zero require zero emissions of trains?
For anyone reading, the climate crisis is real, it is serious, and it is caused by human societies. Whether you believe net zero goals are likely to be met, doesn't change anything about the fact that ordering new trains that can't be used for more than ~ half their lifespan if the goals are met is foolhardy to say the least. Especially when it is likely to be more expensive, if only because of the risk pricing ROSCOs will put in due to this scenario existing.A plan that is unfunded and mentioned in generalised terms with no specific detail is not much of a plan. I also believe 'net zero' is a myth - I'd stake money on it not being achieved within the target timescale.
Up until this post you were arguing against Bimodes, Trimodes and BEMUs - on the grounds that they are unlikely to see wires in the first half of their life. And is this the key point, trains are bought for 35-45 years, not just the next decade. specifying the trains so they can continue to be used on the chilterns if/when it gets electrified, or so that they have reuse value elsewhere on the network is smart forward planning, and refusing to consider it because you don't believe in it is foolhardy and leads to terrible investment decisionsMuch more likely than the electrification of the Chilterns is the development of battery technology and this appears to be the most likely option Chiltern will investigate when sourcing new trains.
In short, there are already more Diesel-only trains on the network than we can use in the long term. We shouldn't be expanding that problem by ordering diesel-only trains for Chiltern. Personally, the last diesel-only trains should have been the 168/170/172s
Theirs so many places begging for their sprinters to be replaced It would be easy to offload any diesels that would get made for the Chiltern line. This idea that if their was electrification would mean they would have to get binned is silly. It's not that long until turbostars will need replacing either, some lines will never justify electrification and having some non ancient diesels around is good insurance in case battery technology doesn't improvethey would be a self-fulfilling prophecy
you say you want something diesel powered WITHOUT a pantograph or passive provision for one; that excludes bimodes, trimodes and BEMUs, so you are arguing against those.No, I wasn't. I was simply stating that the Chilterns are unlikely to be wired within the next generation so ordering units with pantographs, or even passive provision for such, is likely to add unnecessary cost to any newbuild units with a predicted life of service on Chiltern routes.
Both GWR and Northern (and allegedly Scotrail) are in the process of procuring new trains to replace their sprinters - by the time Chiltern would potentially be cascading anything, the sprinters would be long gone.Theirs so many places begging for their sprinters to be replaced It would be easy to offload any diesels that would get made for the Chiltern line. This idea that if their was electrification would mean they would have to get binned is silly. It's not that long until turbostars will need replacing either, some lines will never justify electrification and having some non ancient diesels around is good insurance in case battery technology doesn't improve
- As others have pointed out, something is seriously wrong if no steps get taken to decarbonise the chiltern railway in the next 20 years, let alone the 40 years new trains would last.
Conjecture but that points to something like the 756 with the pantograph being added later if its deemed so unlikely to be useful. But the ROSCO might prefer the pantograph to be there (or at least tested on a few units like two of the 717s were) just to make the sets more versatile for any future market.As I've already suggested, diesel-battery hybrid is surely more likely to be the route taken with no current prospect of electrification.
How does Chiltern compare to GA in terms of required range - don’t the 755s have smaller fuel tanks than sprinters etc?Conjecture but that points to something like the 756 with the pantograph being added later if its deemed so unlikely to be useful. But the ROSCO might prefer the pantograph to be there (or at least tested on a few units like two of the 717s were) just to make the sets more versatile for any future market.
That is going to be the counter argument. Something future proofed but has a cost up front (to build) and operating cost (range, weight).How does Chiltern compare to GA in terms of required range - don’t the 755s have smaller fuel tanks than sprinters etc?
That is correct - from reports from @dk1 they can just about do one day in service if starting with a full tank - on the GA services, with the pantographs up during layovers at stations.How does Chiltern compare to GA in terms of required range - don’t the 755s have smaller fuel tanks than sprinters etc?
TfW's 230s are Diesel Battery Hybrids and I'm pretty sure the D-Stock don't have pantograph wells.A diesel-battery hybrid WITHOUT a pantograph or passive provision for one, as @12LDA28C is apparently calling for, would be a completely new design, I can't think of anything in the UK that comes particularly close to that.
A diesel-battery hybrid WITHOUT a pantograph or passive provision for one, as @12LDA28C is apparently calling for, would be a completely new design, I can't think of anything in the UK that comes particularly close to that. And that is only one reason I think that is a highly unlikely outcome, but if it happens it would be a new design.
Fair point, though I excluded it as it isn't a new train (and of course, vivarail is very much no longer with us - so it seems unlikely Chiltern will be getting 230s / D-trains)TfW's 230s are Diesel Battery Hybrids and I'm pretty sure the D-Stock don't have pantograph wells.
Wasn't that an enormous failure? In any case, it's not a new-built, and you couldn't order more 168s/170s anywayOr maybe a development of the Class 168 diesel/battery hybrid which was recently trialled on Chiltern routes perhaps?
You still need a way to charge the batteries. Yes, as per your other responses, you could use a diesel engine to do that but that is still a problem regarding emissions. Far better to electrify large parts of the network and use the OHLE/3rd rail to charge the batteries, as Network Rail's TDNS recommended.Much more likely than the electrification of the Chilterns is the development of battery technology and this appears to be the most likely option Chiltern will investigate when sourcing new trains.
While you do make a good point there, the fact that we are unlikely to electrify means we are unlikely to save nature from climate collapse. It's so very irresponsible not to allow for a future where we actually manage to save ourselves. I agree that fitting the pantographs from day one would incur unecessary maintainance for a component that won't be used for many years. So yes, leave the pantograph off by all means; but for all our sakes make sure to have provision to add it later.No, I wasn't. I was simply stating that the Chilterns are unlikely to be wired within the next generation so ordering units with pantographs, or even passive provision for such, is likely to add unnecessary cost to any newbuild units with a predicted life of service on Chiltern routes.
Almost all those lines with Sprinters also need units with a pantograph (if building new) or cascaded DMUs from somewhere that's being electrified. Even today, I expect there are a huge number of DMU diagrams that spend part of the day under the wires (or on 3rd rail lines). My go-to example is Shrewsbury-Wolverhampton - with a planned service of at least 3 trains per hour, some with four coaches, it is plenty busy enough to justify electrification in my view. However, the current stock would need to be replaced with EMUs (in the case of West Mids. services) and bi-modes (for TfW services) for electrification of that stretch to actually have much (if any) benefit.Theirs so many places begging for their sprinters to be replaced It would be easy to offload any diesels that would get made for the Chiltern line. This idea that if their was electrification would mean they would have to get binned is silly. It's not that long until turbostars will need replacing either, some lines will never justify electrification and having some non ancient diesels around is good insurance in case battery technology doesn't improve
There are already more diesel only trains than the network needs long-term - we shouldn't be worsening that by ordering even more
I disagree with this statement, given the limited enthusiasm by government to electrify the network. By 2035, there will likely have been very little additional electrification on the national railway network other than the already committed projects on the Transpennine and Midland Mainlines. By 2035, all those Sprinters and Network Turbos will need to have been replaced and without significant electrification in progress, I don't see diesel or battery bi-modes making sense.In short, there are already more Diesel-only trains on the network than we can use in the long term. We shouldn't be expanding that problem by ordering diesel-only trains for Chiltern.
Given the Met Line trains to Amersham, etc... use 4th Rail, would having a unit compatible with that not be a good idea. You could extend it to Aylesbury if you wanted as well.I disagree with this statement, given the limited enthusiasm by government to electrify the network. By 2035, there will likely have been very little additional electrification on the national railway network other than the already committed projects on the Transpennine and Midland Mainlines. By 2035, all those Sprinters and Network Turbos will need to have been replaced and without significant electrification in progress, I don't see diesel or battery bi-modes making sense.
Say new trains come into service in 2030-2035 - they would be in service for 35-40 years, so until 2065-2075 - many routes will be (partially) electrified well before then, and the few lowest-frequency routes across the country that don't touch electrification anywhere, could be served by the 19x fleet. Diesel certainly won't be acceptable anymore long before 2060, I'd not even be surprised if diesel in Urban areas becomes societally unacceptable by 2040 - so any new units need to be designed to remain useful by making adaptation to BEMU or EMU (or something else) easy - the 80x fleet, and the FLIRTs both do this in slightly different ways. the 19x fleet, on the other hand, is designed in a way where it can't realistically change traction system - meaning that an end to diesel would require replacing the unit. ordering many more units like that, when the 19x by themselves already have more than the quietest routes could ever require is foolhardy, as it could lead to many units requiring early retirement.I disagree with this statement, given the limited enthusiasm by government to electrify the network. By 2035, there will likely have been very little additional electrification on the national railway network other than the already committed projects on the Transpennine and Midland Mainlines. By 2035, all those Sprinters and Network Turbos will need to have been replaced and without significant electrification in progress, I don't see diesel or battery bi-modes making sense.
The current presumption against approval of third rail installations from the ORR applies solely to Network Rail-operated third rail installations. It specifically excludes installations operated by London Underground under their working practices.No, you couldn't. It's extremely unlikely that any extension of 3rd/4th rail electrification would be sanctioned.
Transfer of the line to London Underground would allow fourth rail installation, although as previously noted, at that point just extend the Met and be done with it.
That's what the ORR says in their documentation on their presumption.So you believe the concerns and considerations which would prevent the expansion of third rail operations on NR do not apply to LU infrastructure?
Without a presumption against, there is no reason to believe they would not grant such approval. Or they would have made a similar presumption against LU installations.Just because LU installations are excluded does not mean that any such expansion of the LU would meet with approval.
Return the Met back to Aylesbury indeed.
An extension of the Metropolitan line beyond Amersham is unlikely to happen for the justifications that the Met Railway was cut back to Amersham: sparse population, greater distances, and more trains required. An escalator being built to the moon is more likely to happen than this.Return the Met back to Aylesbury indeed.
I didn't say it was a good idea or not (i have no view on it either way) but people mentioned extending the Met there i merely added it would be a return.No thank you. If that's such a great idea why was the line only electrified as far as Amersham in the 1950s?
Making a deal with TfL to extend the line back to Aylesbury is a much cheaper way to deal with the problem of the Aylesbury via Amersham line than attempting a 25kV or dual voltage electrification system.An extension of the Metropolitan line beyond Amersham is unlikely to happen for the justifications that the Met Railway was cut back to Amersham: sparse population, greater distances, and more trains required. An escalator being built to the moon is more likely to happen than this.
The Chiltern EWR units will see OHLE between Bletchley and Milton Keynes, with some prospects of wiring Bletchley-Calvert-Bicester-Oxford-Didcot.What's the relevance of that question? Regardless of what routes other DMUs operate over, Chiltern's new units will most likely not see OHLE for a minimum of 20 years, if at all. Unless you can provide evidence of some future plan for the electrification of the Chiltern route within the lifespan of these units, specifying pantographs or even passive provision for such adds unnecessary cost for no benefit.
