Cheshire Rover
I've noticed a Northern class 150 sat at platform 11 at Man Picc that is marked up not to be moved. I first spotted it last week and it was still there tonight. Does anyone know why it is parked there?
you could climb under and unbolt the driveshafts..
Depends on where the Final Drive is, if it's part of the bogies, then it needs skates, if not, you could climb under and unbolt the driveshafts..
150145 has a seized final drive unit, it's been there since last Tuesday, no one can work out how to move it.
The train now arriving at platform 12 is.... hock:
Is there a possible problem with fitting wheel skates alongside a platform?
Haven't seen the procedure close up though, so that could be bow locks...
If you can't put it on skates, without causing severe track or unit damage, the only thing I can think is to strip the final drive in situ, or get a crane out (taking down the OHLE in the process!)
What's the problem with getting it on skates in situ?
As for the dismantling of the final drive in situ, that would be my next suggestion too...shame it doesn't sound like there is an easy way to disconnect them from the wheels themselves
PS: 11 doesn't have as many trays as the other platforms.
...you don't want to be doing that on your back. Or with an audience...
Or in a puddle of diesel, oil and human excrement.
Those 150s are awful things. Cut it up where it stands, I say.
Shirley you just dig a hole (or holes) in the platform down to track level and install the skates?
At piccadilly, no chance....
